C63/C63S AMG
Service reset procedures for 17 C63S
Old Nov 12, 2018 | 06:47 PM
Art138's Avatar
2017 c63s coupe Fordfgt Supercar
yes probably in a search function somewhere but after countless YouTube DIYs not working for me. Once I get to the service message it will not scroll down for me to get to the part to delete it. Any hints will be helpful.
Old Nov 13, 2018 | 10:11 AM
bgm130's Avatar
2016 C63S
you need to access the workshop menu. same as enabling dyno mode here is the steps. i had to remove the push button each time and actually insert the key to have any luck.
How do you Enable Dyno mode?
  • Turn Ignition to Position 1
  • Make sure odometer is on the screen between the gauges
  • Press and hold "Answer call" and "Ok" together
  • After about 5 seconds a new menu will appear on the screen (this is the same menu to reset service notice).
  • Go to "Roller test"
  • Check off the box and BE CAREFUL, this turns off all the computer assistance(esp, tcs, abs)
  • Note, this menu will stay active as long as the car is left on. It will show up as a new menu selection "workshop"
