C63S Coupe California Front License Plate Bracket
If anyone is interested, I've attached the 3d printable STL (model) file, although I can't guarantee it will work since that depends on your ability to 3d print, the material used (I used PETG but ABS would work too), the 3d printer used, and a lot of other things. I painted mine to give it UV protection. It's only been tested on my 2018 C63S Coupe, and no I won't design a custom one for your car. Basically, if you do use this, you're on your own (but if you can successfully print it, you'll know before you mount it if it'll work).
Foam Tape:
Zip-Ties:
https://www.cravenspeed.com/the-plat...-for-mercedes/
Foam Tape:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Zip-Ties:
