C63/C63S AMG
Spacer question
Old Jan 2, 2019 | 12:12 AM
Mr. Pink's Avatar
W205 c63s AMG
Spacer question
Alright so I know everyone runs 15mm spacers and whatever, however I only need maybe 5mm all around with my wheel and tire setup, I recall something along the lines of 5-8 non hubcentric work, and anything between 8-15 will not work. Is this correct? Just trying to make sure before I go order something, and I want to get an idea for when I test fit the wheels and tires without anything. Again I'm interested in the 5-8mm range
Old Jan 2, 2019 | 12:36 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
We can custom make spacers, if you want to go the custom "One off route". We produce and stock Lambo Huracan and Audi R8 spacers in 11mm but make custom sizes as well.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Jan 2, 2019 | 12:56 PM
Mr. Pink's Avatar
W205 c63s AMG
Might need to go this route! I will know a bit more exactly what I need when I get my wheels back, they just got powder coated. Im thinking I'm gonna need a 5-8 in front and 5-7 in rear
Old Jan 2, 2019 | 02:18 PM
Schulminator's Avatar
2015 C63s Sedan
The 5mm H&R units fit our bore, but do not have the hub lip to fit the wheel. I’ve been running them in the rear for a few months without issues. 5mm would be the max I’d run without being hubcentric.
Old Jan 2, 2019 | 03:12 PM
ScottsC63's Avatar
2015 C63 AMG sedan
Are you guys all lowered that run the spacers? Also I’m assuming coupes?
