C63/C63S AMG
C63S PASEENGER WINDOW
Old Jan 13, 2019 | 08:35 AM
Terry 45's Avatar
2016 C63 bril
Hi guys anyone experienced when closing the passenger side window the window closes full then opens again half way down, this happens whether the driver closes the window with his window controls or with the passenger window control.
Old Jan 13, 2019 | 08:53 AM
japamg's Avatar
Final Edition C63s / RS3 Sportback
It happened to me in the driver window.
Just lubricate well the plastics where the window closes and that should work.
Old Jan 13, 2019 | 11:49 AM
Terry 45's Avatar
2016 C63 bril
hi thanks for the reply but I dont understand what you mean by lubricating the plastics.
Old Jan 13, 2019 | 12:16 PM
japamg's Avatar
All the rubber trims where window fits when closed. Use some grease to lubricate it
Old Jan 13, 2019 | 12:22 PM
purplewidow's Avatar
2019 c63s coupe, 2008 s63 sedan, 2007 335i coupe
try this for rubber trim "Nextzett gummi pflege rubber care stick"
Old Jan 13, 2019 | 01:44 PM
Terry 45's Avatar
2016 C63 bril
I still dont understand how lubricating the rubbers will help sort out the window opening half way after the window is closed fully.
let me explain what the problem is again, when I close the passenger side window full the window then opens halfway on it's own
Old Jan 13, 2019 | 02:50 PM
RDOCA's Avatar
2016 C63S Sedan
The problem is that it binds some in the track and the window reverses as it is a protection so that if you have your hand in the way it will not hurt you but reverse.
It is binding some or dragging(enough to trigger the reversing) and it probably needs adjusting and not just lubing the track.
Take it to the dealer and have them adjust the glass in the track.
