Auto Talent | KW Suspension Oldest Dealer
[SIZE="3"]Applications: H.A.S. | V3[/SIZE]
[SIZE="3"]Please PM or email:[/SIZE][SIZE="3"] Golan@AutoTalent.com for pricing and info![/SIZE]
[SIZE="3"]We are the oldest KW Suspension dealer![/SIZE]
KW Height Adjustable Springs
Part # 25325081 (Sedan) / Part #25325081 (Coupe)/ Part # 5325089 (Convertible)
The KW Suspension Coilover spring kit is used for lowering the vehicle in combination with the original dampers, even when electronic damper control is installed. This lowering solution from KW optimises the dynamic performance and the steering behaviour without the electronic damper control deactivated.
For this solution vehicle specific adjustable spring seats with adjusted KW lowering springs and the matching elastomer as well as the dust cover system will be used. This complete conversion allows an individual an adjustable lowering solution without the need to purchase a full coilover kit.
Features:
- Individual height adjustability of the original suspension kit
- OE suspension system also with electronic damper control stays active
- Improved optic and vehicle dynamics
- Optimal performance
- Better steering behavior
- Front Lowering: 0-20mm (0.0-0.8 in.)
- Rear Lowering: 0-30 mm (0.0-1.2 in.)
Part # 35225081 (Sedan) / Part # 3522089 (Coupe)
Want full control? The KW V3 gives you multiple settings for both rebound and compression. You have full access over ride comfort and handling to dial in that perfect setup. Race teams rely on adjustments to get that perfect lap time and having shock controls at your fingertips is key. KW V3 features -
Separate adjustments for compression (14 positions) and rebound (infinite settings),
Stiffer springs over stock for less bodyroll than the standard suspension,
Stainless steel strut/shock bodies and composite spring perches for superior corrosion resistance,
- Individually height-adjustable:
- Front = 5-35mm lowering
- Rear = 25-45mm lowering
Expert engineering and design for ease-of-use and long durability,
Whether you track the car often or only use it for backroad carving the V3 will give you the tools to set up an ideal handling condition. You can crank it up for smooth and fast surfaces or soften it for city or rough roads. Since each shock is 2-way adjustable you can alter the front-rear balance to account for brake dive or squat during power application coming out of the corner. You are in total control!
Coil over suspensions are better engineered suspension options compared to a standard shock + spring package. Since the springs and shocks in a coil over are designed by a team of engineers to work together, there is much better suspension travel and more precisely tuned specifications for spring and shock rates. Using separate shock and spring specs may result in premature coil bind or shock bottoming. And most coil over kits offer more features than the traditional packages. Coil overs are also more useful when larger wheels/tires are used because you can precisely set the ride heights to clear the new tires.
[SIZE="3"]How to Place Your Order[/SIZE]:
[SIZE="2"]Phone Domestic:[/SIZE][SIZE="2"] (855) 973-2757 X 103
Phone International: (310) 231-7800 X 103
E-mail: Golan@AutoTalent.com
Website: www.AutoTalent.com[/SIZE]
[SIZE="3"]Payment:[/SIZE]
Attachment 439933
[SIZE="3"]Installations:[/SIZE]
[SIZE="2"]Feel free to visit us at our facility in Los Angeles, CA.
We install everything we sell.
19143 S. Hamilton Ave
Gardena, CA 90248
[SIZE="3"]Shipping: [/SIZE]
[SIZE="2"]All orders are shipped via FedEx, UPS, USPS and Pilot.
International, Hawaii and Alaska customers: Please contact us for the best quote possible. [/SIZE]
[SIZE="3"]Hours of Operation: [/SIZE]
[SIZE="2"]Monday through Friday: 10AM-7PM Pacific Time
Saturday: By appointment only[/SIZE]
