C63/C63S AMG
Largest tires that can fit on stock C63S sedan?
Old May 15, 2019 | 12:58 AM
GCheng's Avatar
2016 C63S
Apologies if this has been talked about a lot but i haven't been able to find a conclusive answer.
Car is a 2016 C63S Sedan, im wondering what the widest tires I can get while leaving the car stock (No lowering, spacers, etc).
Also if someone could post the exact wheel dimensions to match those tires it would be greatly appreciated!
Old May 15, 2019 | 09:57 AM
Zeek1's Avatar
W205 C63s
all there mate. this tread should be closed.
https://mbworld.org/forums/c63-c63s-...et-s-hear.html
Old May 16, 2019 | 01:30 AM
GCheng's Avatar
2016 C63S
Ive personally been to that thread but just for peace of mind id like to double check
Would...
265/35/19
295/30/19
Fit on a stock sedan with no spacers, lowering etc? (There was mention of lowering etc in that thread which confused me)
And would those tires fit on the following rims?
19x9.5
19x10.5?
Old May 17, 2019 | 12:11 PM
ggonzaga's Avatar
2020 E63S
I did 285/30/19 on mine for rears. Fronts are stock size. I was told any wider would rub on the sedan but I've heard otherwise from others. I don't want to go through the pain of doing spacers and 285s tend to hook enough
Old May 18, 2019 | 03:35 PM
Pete H's Avatar
2018 C63 Cabriolet
Would...
265/35/19
295/30/19
19x9.5
19x10.5?
Yes... they will fit the wheel... as will a 305. The problem is the sedan rear prob won't accommodate the width, coupe? No problem.
Old May 20, 2019 | 03:05 PM
Blaque Diamond Wheels's Avatar
Former Vendor of MBWorld
2014 S63
You can run the 265/295 set up in the 9.5/10,5 wheels
