C63/C63S AMG
AWE simulator install - different plug?
Old May 17, 2019 | 05:06 PM
DMB_C63AMG's Avatar
2017 C63 s Coupe
Hi,
Received my AWE simulators today and installed the passenger side first and everything went well. When I got to the driver side, it looks like there is a little extension compared to the passenger side. On the passenger side, you only have to disconnect the plug from the motor and plug the simulator - Done. On the driver side, there is a small wire coming out of the motor with a plug(lower plug in the picture) about 6" long that goes to a little sensor look a like (looks like the AWE simulator) and the wire that I'm holding in my hand is the one at the opposite end of that sensor and there is 3 pins sticking out of it. This is where the simulator should plug in to but obviously doesn't fit. It's seem like the plugs are reverse. the one coming out of the motor is the one that fits the simulator, but it won't do nothing if I connect the simulator to that as the signal doesn't go back to the computer. I'm confuse!
Please help
