C63/C63S AMG
M177 spark plugs
Old Oct 22, 2021 | 01:43 PM
raphman's Avatar
'16 C63s
I recently did mine as well and uncovered that the OEM spark plugs are the BOSCH 7434, which can be found for MUCH cheaper through your normal auto parts stores
https://www.oreillyauto.com/detail/c...plug/bosq/7434
Old Nov 1, 2021 | 01:02 PM
noremaC's Avatar
17 C63S Coupe PTG1000
Tackled the change last week. It's honestly not too big of a deal. Took about 3 hours with a few breaks for calls, lunch etc. Overall, it wasn't a terribly difficult job, just a lot of tight spaces and removing components to get access to the coil packs.
I'd say the most PITA step of the job was removing the coil packs. Pro tip: as you pull up, wiggle the coil pack to free the rubber "boots" from the plugs.
Went with 1 step colder HKS Racing Plugs, which I believe are Nissan GTR plugs. They were costly (about ~$450 for 8 of them) but you gotta pay to play with these big turbos. I gapped them to .026 at the recommendation of PTG.
I am running 93oct, PTG1000 turbos and catless downpipes on a Kirkland Hans tune. These are the original plugs at ~10k miles, with about ~2k of those miles being on big turbos. They look filthy as hell. I'm honestly shocked at the condition after 10k miles and no surprise that I had a misfire, with likely more to come in the near future.
I started to get a misfire code on cylinder 8 when I would kick-down and go WOT, the car would automatically downshift into 3rd, begin to pull for 2-3 seconds, throw a blinking CEL and go into limp mode. The car would idle really rough and shake. If I turned it off, it went away. It was strange because if I was doing WOT pulls in manual, I did not have the issue.
Because I am a 2017 PFL coupe, I have the old/outdated version of coil packs, so I decide to swap out the coil pack on cylinder 7 & 8 with the updated version, just in case. You can see the picture below, the difference of the outdated vs. updated version of the coil pack (old = left, new = right).
Old Nov 1, 2021 | 02:25 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
Where did you order the coil packs from and what did they run you?
Old Nov 1, 2021 | 02:30 PM
noremaC's Avatar
FCP Euro - Lifetime Warranty. Part number ending in 4202 is the updated one. The part number ending in 9500 is the old/outdated version.
Here's the link:
Mercedes Ignition Coil - Genuine Mercedes 1779064202
Old Nov 1, 2021 | 04:19 PM
noremaC's Avatar
Additionally, for those of you looking to gap any 12mm plugs for the M177, here's a tool I picked up (again, at the recommendation of PTG) to effectively & safely gap:
Amazon Amazon
Old Nov 1, 2021 | 05:33 PM
skratch77's Avatar
2005 E55
I paid 286 for the plugs on ebay but that was before Brandon flushed the country down the toilet
Old Nov 1, 2021 | 05:42 PM
  #32
noremaC's Avatar
I think you can find them for around 25/plug.
Was trying to honor the source, I suppose.
Old Nov 1, 2021 | 08:49 PM
  #33
SJGetsome's Avatar
W205 C63 AMG Coupe
Here's the link:
Appreciate it. And good call on going with FCP Euro. I went with them when I ordered all my brake parts due to their replacement warranty.
Old Nov 19, 2021 | 06:47 AM
  #34
dlefty's Avatar
/////PRO
@noremaC how does the car feel / run after the HKS 1-range colder plugs?
Old Nov 19, 2021 | 08:54 PM
  #35
SJGetsome's Avatar
W205 C63 AMG Coupe
So I decided to tackle the spark plug change on my car tonight. How the hell did you all get the freaking coil packs off? I have all three bolts undone and they are wiggling around, but it is like someone is on the other end holding it affixed to the spark plug. I am about to lose my mind; I've never had a car where the coil packs were this difficult to remove for a simple spark plug change. The car is cold as I had it sitting in the garage. Any tips or tricks would be greatly appreciated.
Old Nov 19, 2021 | 09:39 PM
  #36
skratch77's Avatar
2005 E55
Fing pull lol they are a pain. You can also wedge a wrench under and use a screwdriver to pop up.
Old Nov 19, 2021 | 09:53 PM
  #37
SJGetsome's Avatar
W205 C63 AMG Coupe
You ain't kidding. I was worried I was going to break them. I was finally able to start getting them out though by using some other items in the garage to assist. What a P.I.T.A.
Old Nov 19, 2021 | 11:17 PM
  #38
raphman's Avatar
'16 C63s
1000% this. I used a shoelace - wrapped it around the coil pack and ****ing YANKED on that **** til it came out. On two cylinders, the pack came out but the boot was still in.. that was fun.
Old Nov 20, 2021 | 02:22 PM
  #39
noremaC's Avatar
@dlefty runs like it did before, so, great. Probably worth investing in if you’re running big turbos.
Old Dec 27, 2021 | 08:33 PM
  #40
Jerome NC's Avatar
GLC AMG 63s coupe
Originally Posted by PaulC63s
What are the intervals for spark plug change? I think there's something off how my car builds boost after stage 2 tune. When i slam on the throttle (while rolling in 3rd) the car goes quick ,but the pull and G force doesn't increase until 1 sec or so (after 4k rpm). Is this just increased turbolag with the stage 2 tune?
Did you find the solution, because I have the same problem with a cut between 3500 and 4000 rpm and hesitations in the acceleration?
Old Dec 27, 2021 | 09:00 PM
  #41
dlefty's Avatar
/////PRO
Both of you sound like most likely something within the tuning itself.
Turbo lag doesn’t increase unless going to bigger turbos.
Could new factory or 1-range colder plugs help?…yes they could, but you are both most likely suffering from something within the tune.
Now if you have 10k+ miles post tune on plugs I’d absolutely change them.
Old Dec 27, 2021 | 09:13 PM
  #42
Jerome NC's Avatar
GLC AMG 63s coupe
Thank you for your opinion, I take note of it. it is 15K miles. It's something that has been going on for 2 months, I didn't have this type of problem before,
it grew continuously ... I have a stage 2 preparation with a carbon air box & removal of catalytic converter and the DPF. nothing has changed mechanically and electronically since. I will change in all the coils and spark plugs... I hope to have a result
Old Dec 27, 2021 | 09:28 PM
  #43
dlefty's Avatar
/////PRO
Anytime and happy to help! I avoid “opinions” I just share actual experiences I’ve had😁. Too many opinions based on zero experience 🤣
Old Dec 27, 2021 | 09:35 PM
  #44
Jerome NC's Avatar
GLC AMG 63s coupe
Advice on the model or the quality of the spark ?
Old Mar 11, 2022 | 02:17 AM
  #45
anwar_hamoude's Avatar
2016 C63 AMG
2016 C63W
Thanks for the information on ignition coils.
I just ordered a set of ignition coils from ngk.com but unfortunately received ignition coils with the outdated part number. I am sending them back.
I installed new plugs 4,000 miles ago.
Then I recently installed Weistec Stage 1 Tune; get misfires under heavy and after heavy acceleration but no error codes. With Stage 1 Tune Weistec recommended to gap plugs 0.022-0.024. And new ignition coils.
For plugs I purchased a set of NGK 97566 SILZKFR8F7S. Planning on gapping them 0.022.
Old Mar 12, 2022 | 02:21 AM
  #46
koifysh's Avatar
2007 E350
What is the difference between the updated coil version and the old one? Seems like external differences from the pics above ^^ and not internal
Old Mar 12, 2022 | 03:01 AM
  #47
2016 C63 AMG
To my understanding the older versions were replaced due to reliability issues.
***For owners of M177***
Old Mar 12, 2022 | 11:05 AM
  #48
DeviantRebel442's Avatar
208 C63s AMG
That is correct. From what I have read some issues happened with soldering connectivity and internal components after several heat cycles. It's sporadic and doesn't always happen but can cause some misfire problems. I recently just replaced all mine with the new ones in my 2018 C205.
Old Mar 12, 2022 | 07:34 PM
  #49
2016 C63 AMG
Are we ready to replace ignition coils one more time!
Order I placed for ignition coils P/N: 177-906-42-02 was cancelled.
Apparently there's been another update P/N: 177-906-02-06.
Seems I am extremely lucky! I'll have the latest version of ignition coils.
