C63/C63S AMG
Bluetooth sound quality?
Old Aug 21, 2019 | 09:47 PM
ShaneN.'s Avatar
2018 e63s edition 1
Just got my 17 a month ago and noticed that sound via XM radio is actually better sounding with more base than when I play spotify or mp3's off my phone over bluetooth. I feel like that should be the opposite of what should be happening as in my 2012, music over xm/satellite radio sounded worse. Higher treble notes and voices in the music also get distorted from what sounds like the centre dash speaker. Anyone noticed this?
Old Aug 21, 2019 | 10:36 PM
zibby43's Avatar
'20 GLC300 SUV
100% accurate. I actually had the same issue in my departed '13 W204 C63, my departed GLE400, and my current W205 C43. Haven't tried the BT in my '20 GLE450 yet.
Do you also have to turn up the volume higher than anticipated (including on the phone itself) to get adequate sound volume?
Old Aug 22, 2019 | 02:10 AM
ShaneN.'s Avatar
2018 e63s edition 1
That's weird, in my 2012 I found that XM radio sounded worse than music off my phone via bluetooth. It's weird now having more bass and overall better sound from XM.
I can't tell about the sound volume since there is no volume level reference to show how loud the music is turned up, and also the volume "button" is endless scrolling so I can never tell when it's fully down either. I was thinking about trying an AUX cord but looking around in the centre console I didn't notice a spot to plug it in.
I wonder if this is normal, I was going to mention it next time my car was in for service.
Old Aug 22, 2019 | 03:30 PM
zibby43's Avatar
'20 GLC300 SUV
Have you tried connecting your phone via one of the 2 USB slots in the center console? There is no AUX input in these cars - just the BT, USB, and SD options.
Old Aug 22, 2019 | 05:52 PM
ShaneN.'s Avatar
2018 e63s edition 1
I'd have to find a cable that went USB to AUX, maybe I'll try that.
Old Aug 23, 2019 | 12:16 PM
Tuxdude's Avatar
2019 AMG C63S
When you play audio over Bluetooth it uses some or other form of compression due to low bandwidth over the BT channel. The codec (i.e. compression) chosen depends on the source device, i.e. phone here. The default BT codec is lossy and hence its quality is not as good as playing audio directly from a USB stick or an SD card. Different apps choose different codecs. For example, Spotify uses higher quality codecs.
To experiment, you can try playing audio in different apps on your phone when connected over BT to the car stereo. I always recommend USB sticks/SD cards any day because you can control the audio quality (by choosing the codecs) and you don't have any shortage of bandwidth when connected over a physical interface. Another advantage is, while traveling you don't lose signal and/or data connectivity for streaming.
AUX is an analog interface and hence you're going to experience some loss in quality whenever you're converting digital to analog or analog to digital. I'm not sure if there is an AUX->USB connector, and even if there is one you're performing the conversion twice (from a digital medium) and you're going to see loss in quality there too.
