Keyless entry behavior
then unlock with door handle. Is this normal behavior ?
Ifyou lock (only once) using the keyfob you can unlock the door using the door handle.
Only if you locked twice (in quick succession), the keyfob stops transmitting (until you press any button on the fob again). This will prevent the keyless entry from working and will require you to unlock using the keyfob again.
Is this not true with 2018s? OP - can you try locking just once using your keyfob to see if unlocking using the door handles work?
Do know the double lock trick too which helps the car not get boosted and stolen
i think you unintentionally deactivated your fob when you locked the car and that put the fob to sleep so when you touched the door handle it didn’t unlock. When you then used the fob you woke it and it unlocked.
you can make the fob turn off by double clicking the lock button. The light on the fob blinks followed by a long light.
