C63/C63S AMG
Anyone running 265s on front of Sedan?
Old Oct 15, 2019 | 12:08 AM
ShaneN.'s Avatar
2018 e63s edition 1
I need all four new tires and I think I'm going to go with pilot sport 4s. I really want to run a 285 in the rear of the car, so a 265 is what would match up best after doing some numbers on a tire calculator. Otherwise I might go 255/275, but really want the 285 rear as that seems to be about as wide as we can go on stock offset/wheels. So, is anyone running 265's on the front with zero issue? I'm stock height now but might do h&r springs or kw has in the future.
Old Oct 15, 2019 | 05:50 AM
GCheng's Avatar
2016 C63S
Im running 265/295 on a sedan with no issues at all (stock height)
Old Oct 15, 2019 | 09:35 AM
superstarR's Avatar
AMG C63S
I’m running 255/285 PS4’s on a sedan with no mods on stock wheels with no issues. Not sure if you need 265’s on the front.
Old Oct 15, 2019 | 09:07 PM
Drisso88's Avatar
Veteran: Marine Corps
Current: 2017 C63S Prior: 2016 CLA45, 2015 Evo X Final Edition
I'm running 265/35 up front and 295/30 in the rear, no issues
Old Oct 15, 2019 | 11:41 PM
RDO247's Avatar
C63S
Ran 265/30 & 295/30 PS4S for along time on factory 19’s with no issues, was lowered 20mm on KW HAS and K-Mac camber kits.
I run 265/305 AR-1’s now.
Old Oct 16, 2019 | 01:31 AM
ShaneN.'s Avatar
2018 e63s edition 1
Damn, reading this now I want to step up to a 295 rear but I know a 275 will not fit front, and then you end up with more of a difference in tire height. The goal is to create as close to difference in diameter to stock.
When you punch all this into a tire calculator ( https://tiresize.com/comparison/ ):
Stock tire size: 245/35/19 Front & 265/35/19 (tire diameter 25.8" front/26.3" rear). So half inch larger diameter in rear.
With a 265/35/19 front & 285/35/19. (tire diameter 26.3" front/26.9" rear). Rear tire being 0.6" bigger in diameter. Not far off stock in difference.
and now knowing that a 295 fits in the rear...
265/35/19 front & 295/35/19 rear. (tire diameter 26.3" front/ 27.1" rear) Difference of 0.8"
You actually end up with a larger sidewall and taller tire in the front versus the back when doing this. Not by a large margin, but...
