2019 C63S Car Alarm Going Off?
Has anyone else had this happen? Is there some motion sensor at the front of the car that could have set it off? I can confirm there was no impact to the vehicle at all. I have a cabriolet and the top has been closed both times, too. Only thing I can see from the Connect App is that my starter battery shows "partly charged." Not sure if there is any correlation there at all. I have been only driving a about 10 minutes per day for the past several days.
Just checking to see if this is an aberration or a known issue? Anyone?
The fault was causing a battery drain and managed to kill the battery completely. Same symptoms. Alarm going off for no reason.
Dealer should be able to help.
