C63/C63S AMG
Need info on widest size wheels for c63 sedan!
Old Dec 16, 2019 | 11:51 PM
Oddguy's Avatar
W205 c63
Question Need info on widest size wheels for c63 sedan!
I've been looking around the forums but i cant seem to find some solid information.
Any information is greatly appreciated!
What is the widest size wheels and tire for a c63 sedan on stock suspensions?
Im looking for 18 inch wheels to combat the new york city roads.
Need information on offset, 18 inch wheel width for front and rear, and largest sized tires that can fit without any fender work or suspension / camber work.
I've heard you can fit a 19x9.5 in front and 19x10.5 with a really high offset like 56+ in the rear.
Will 18 inch wheels with these spec clear the suspensions?
Old Dec 18, 2019 | 04:37 PM
kfehling's Avatar
2015 C63 AMG S Edition 1, 2021 GLS63, 2020 McLaren 600LT Spider
Call Finspeed in Austin, TX. They make everything custom ordered to your specs. They are doing a set for my C63 now and I am going an inch wider in the back. I think you can actually go wider than that if you would like. As for Daniel.
Kurt
Here are some pics of the wheels they did for my wife's GL63.
Finspeed saved 19 pounds per wheel over stock. You can tell the difference in ride quality.
