C63/C63S AMG
c63s 2016 wet clutch oil change
Old Jun 23, 2020 | 04:24 AM
Mathew Giddey's Avatar
2016 c63s sedan
Does anyone have the steps to change the wet clutch transmission fluid? Is there adapters and which type of oil do you use?
Old Jun 28, 2020 | 09:25 PM
ahelal's Avatar
2016 C63s AMG
Here is a full step by step for the transmission fluid change including filter. the first PDF file shows you the over all step by step, and each other PDF file is for a particular step (on the first pdf file, all the way to the right of a step will be a red highlighted number, that number corresponds to the particular file you need from the rest of the pdfs. when you open any of the other ones, that same number will be at the top left of the 1st page. As for fluid, I would just get it from a dealer if i were you to make sure its all kosher and safe.
Note: these instructions were what was available through my vehicles VIN 2016 c63s amg, your vehicle may have a different transmission in it. make sure everything checks out before following these steps. Also i am not a professional mechanic just some dude who enjoys working on his car (and looking at repair diagrams lol.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
