Excessive Wear on Inside Edge of Front Tires
2020 AMG GTC Coupe & 2018 Macan Turbo
When I discovered this wear I was surprised. I'm older, 69, and I still drive my cars to the edge of their performance potential. What I can't do anymore is crawl under my jacked up cars (especially with low ground clearance) checking the components for wear and tear, fluid leaks and such. (I miss this.) This tire wear was dangerous. I was going by what I could see from the outside that was 50% wear. Had a front tire blown during a pleasurable high speed drive, I wouldn't be writing this. Some owners who treat this car as a 'plug and play' experience can't recognize a dangerous situation such as this. My Porsche Macan Turbo with Pirelli all-season tires came with a sticker on the dash saying "warning do not exceed 150 mph with factory all season tires." Something like this should be done by Mercedes, perhaps "please examine the front tires frequently for uneven tire wear."
Damn, I'm gonna hurt the next morning
I pretty much always have the tire pressure and temperature screen up on my digital instrument cluster to get an instant health check of the car and to know that everything is within operating range. Any early sign of pressure loss or unusual tire, engine, transmission temps would be noticed quickly.
In town, no big deal.
'17 AMG C63S Edition 1 Coupe, '18 AMG C63S Convertible, '19 AMG GLS63
In my research, I saw a couple people run the 275 front, 305 rear combo without issues. I'm at stock ride height so it should work with no problem. I'll report back or start a new thread once I have the tires installed. I currently have 265s on the front and there looks to be plenty of room for the 275s.
I know 275/35/19 and 305/30/19 was mentioned in this thread; I have the 19"/20" factory staggered setup. May have to try 275/35/19 and 305/30/20 next go around, although the sidewall height of a 305/30 matches up better with a 265/35 than a 275/35. But we're talking about a difference of only 3.5mm.
2018 C63s AMG Coupe not tracked:
15,000 miles and the front tires inside edges are down to the cord while the rest of the tire is about 50% left. The wear is a very narrow strip on the inside edge. The Mercedes service department says this is normal for this car. I disagree. This is a very dangerous situation as the front tire could fail. Not easy to see on the car unless your looking for it because the car sets so low and this edge area of the tire is hidden from view when not on a lift. Mercedes says its because of the powerful engine! I mentioned the car is rear wheel drive! I'm insisting they check the wheel alignment.
I had the same issue with my car, and the thing I noticed was how much the front tires ride on their inner edge when at full steering lock. I always deduced the tire wear to this issue and the wear this caused. The only way to get that extreme of a wear angle compared to the rest of the tire's contact patch has to be from the tire riding on it's edge during a wear-inducing situation (like turning tight in a parking lot).
#32
As others have said, only the toe is adjustable on the C63S, so it isn't an alignmemt issue you can solve without going aftermarket.
I put a 125k on a 2012 S550 and no longer own the car. It performed great with typical maintenance. Only once did I have a tire wear issue much like you describe. It resulted in a blow out at hwy speed.
However, the inside edge cord wear was not on the front tires but only on the RR. All three others were perfect. 50 miles from our 800 mile destination 400/400 trip, the RR blew. That was when the car was a year old. I always inspect the the fronts but my fault for not checking the rear tires closely.
#33
700HP Facelift converted PFL C63 S Coupe
Owning this car has made me more enthusiastic about suspension and handling now and I get my alignment tweaked and checked every 6 months (it's my daily).
Once your alignment is sorted, you will get proper tire wear 👍
#34
Interesting you say that since I had a similar issue with my daily Macan Turbo. I could not take corners and curves. Couldn't set up on them. Went through my first set of tires in 9K. Got an alignment on a whim. It was way out...from the factory. Everything was outside spec. I've mentioned on the Macan forum to have their alignments checked the next time they get tires. It made a world of difference on mine. Made me think I paid how much for what? This is a Porsche? All good now.
#35
#36
I'm wondering do your cars pull to the right or have a crooked steering wheel slightly left? I've gotten many alignments at reputable track shops near me however, none of them could solve my pull to the right, even after new front tires. My wheel is slightly to the left in order to compensate for the pull. Anyone have anything similar?
#37
I highly recommend you go to a specialist alignment shop, they will fix it for you mate. Don't be sucked in by those fancy places, sometimes you need some old school knowledge and a bit of tinkering.
No more crooked steering
#38
Yes, had the exact same problem on mine. It really drove me nuts especially on the freeway because the bloody steering wheel was tilted in order to stay straight. After taking it to one alignment place they completely overlooked it and said it was normal. I was like, come on man. So I went to an alignment specialist in Sydney (Road & Race Performance Rydalmere) and this guy Peter completely fixed it for $120 AUD plus sorted out the "crabbing" issue. So far I've gone there 3 times for tweaks here and there and even if it costs a bit extra, the guy knows what he's doing, and that's worth much more to me.
#39
I just picked up my C63s at the end of March and maybe over the past couple of months have noticed the problem developing as well. Not sure if it’s an alignment issue or possibly a software issue. Does anyone know if alignments are covered under warranty in the US for a certain time period/mileage?
#40
This is a stretch. Any chance it’s from the torque?
Im old. I remember Corvette’s having a problem back in the 60’s. They were running 454cu.in. V8’s. They would twist the chassis and it would fight to go right. Even heard stories of the left fiberglass fenders cracking from it.
Just a thought.
Just a thought.
Jimmy_c63s (08-16-2020)
#43
#44
Just a thought.
Just a thought.
