C63 (Non-S) Brakes
C63 (Non-S) Brakes
It is coming near the time that I will need to replace the brakes all around on my 2017 coupe that I bought last year. I did some searching and found a lot of information for the brakes for the S model, but not a lot for the non-S model. I found the following kit from FCP Euro for the rear brakes that looks like it is for both the S and non-S C63 (https://www.fcpeuro.com/products/mer...230212#fitment). However, I was only able to find the following kit for the front brakes on the non-S C63 (https://www.fcpeuro.com/products/mer...ann-0004204700).
I was hoping there would be something like this two piece rotor kit that would work on the C63, but this particular kit will only work on the C63 S (https://www.fcpeuro.com/products/mer...mbo-0044208420). Does anyone know of any comparable kit out there for the C63 (non-S)?
Any help is appreciated.
2017 c63 amg, Catless DP, Velos tune
I am interested in this information as well. My mechanic gave me two options on replacing the brakes. Oem variety and then an aftermarket version. I’m going to email him and see the difference and then I will pm you with the details. They are master mechanics.
Do you need new rotors? Not sure if there is a two-piece rotor option for silver non S brakes.
For pads ... search on this forum, there are threads with part #s and vendors, topbrakes.com has front and rear Porterfield R4S pads for non-s silver calipers.
Yes, I'm going to need new rotors in addition to new pads. I found brake pad replacement options but made this post more for rotor options. I'm leaning more towards going with the OEM pads. I've seen mixed reviews on the Porterfields.
If you are unsure, I can sell you a 2 piece brembo front brake kit for your non s c63. just let me know. pm me
otherwise, i gave you the part number you need to source on your own.
you asked for a 2 piece brembo rotor, of course its going to look the same. its a 2 piece brembo rotor same as the rotor kit you linked for the s. However it is 360mm OD vs the s has 390mm OD.
If you are unsure, I can sell you a 2 piece brembo front brake kit for your non s c63. just let me know. pm me![Smilie](https://mbworld.org/forums/images/smilies/smile.gif)
This set looks like the correct rotors based on the manufacturer part number 09976423: https://www.fcpeuro.com/products/bra...mbo-2194210212
Would that mean I just add the pads: https://www.fcpeuro.com/products/mer...mer-0004204700 and the wear sensor: https://www.fcpeuro.com/products/mer...or-1715400617b to complete a kit?
I'm just not sure as the FCP Euro website indicates those rotors will not fit my car. However, if you have done it and know it to be a plug-n-play solution, if you wouldn't mind sending me a PM with a kit I would greatly appreciate it.
I got you. When I checked the part number it looked to be the same one from the link I posted. Thank you for pointing out that I was an idiot, haha.
SJGetsome (09-01-2020)
![](https://cimg8.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/20201211_205638_03cc5a492529d832379cba694319f86cf03258f9.jpg)
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/2000x1504/20201212_013631_ecc0bf4ee0179ca5aa44ec45acefee307141c0c1.jpg)
Received 3,798 Likes
2019 C63CS
https://www.fcpeuro.com/Mercedes~Ben...b=9&d=15498&v=
I'm probably gonna try these for my S when my fronts are due. I just replaced the rear pads before Thanksgiving with OEM pads and kept the original rotors.
I just had front brakes done, new pads and rotors, and the rear brake pads replaced along with new wear sensors. Cost was around $1500 at the dealership for everything installed.
jj18 (12-14-2020)
Bedded in the brakes last night. They feel great. Can't tell if there's any improvement over the stock front rotors with just street driving, but initial bite and stopping power are at least as good as stock. Didn't really expect to feel any difference but they look good and saved a little weight.
As for cost, it was about $1,900 for the front and rear pads, rotors and wear sensors. Installation only cost me some time over the weekend.
Oh did you not have to replace/bleed the brake line fluid? That is the tipping point for me in if I were going to do this myself or not. I don't have a motorized pump to get air bubbles out and I don't want air bubbles in my brake lines. Figured MB would have some special step or something off ordinary with replacing brakes/rotors like "hey you should be replacing your fluids too so we'll do it for you right NOW".
Stunna02 (12-16-2020)
Former Vendor of MBWorld
Your one-stop shop for your C63 brake replacement and/or upgrade.
https://racingbrake.com/c/
RacingBrake offers more C63 brake options than all the competitions (Including OE) combined. Do not just replace, upgrade as you replaced.
We don't just duplicate from OE parts like others, we make them fit better and last a LOT longer. Thousands of installations, hundreds of testimonial...
Ask any questions, PM, email, or call us (714-871-6292)
- Brake pads replacing OE pads with RB's low dust & no squeaking pads
- Brake rotor replacing OE heavy/bulky one piece to RB two piece light weight high performance rotors
- BBK upgrade (w/OE calipers) to Black Series 390/360
- Complete BBK system with RB calipers
- Rebuild your OE calipers with RB components
- Carbon Ceramic Brakes upgrade
