C63/C63S AMG
RHD performance seats
Old Oct 21, 2020 | 02:24 PM
japamg's Avatar
Final Edition C63s / RS3 Sportback
Hi guys
Debating with a friend on the possibility of installing a rhd seats on a lhd car...
I would say yes, as all conectors and everything should be the same
What do you think!?
Old Oct 21, 2020 | 04:10 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
I think it'll depend on whether there are any differences between the driver's seat and passenger seat that affect how they connect to the car. If there are, the location of the airbags on the seat will prevent their use. If they're the same between left and right side, it would probably work fine assuming the cables reach the necessary connectors.
Old Oct 21, 2020 | 04:23 PM
superswiss's Avatar
2019 C63CS
Assuming you are not gonna switch them left to right as otherwise the airbags will be on the wrong side, the driver performance seat has more adjustability than the passenger seat. The driver seat can adjust both the lower side bolsters and the upper side bolsters, while the passenger seat can only adjust the upper side bolsters. Since you'll effectively be sitting in the passenger seat if you do this, then you as the driver don't get the full adjustability.
Old Oct 21, 2020 | 05:31 PM
japamg's Avatar
Good point on the side bolsters adjustment, didn’t realise of that
Old Oct 23, 2020 | 02:29 AM
japamg's Avatar
And what about the passenger seatbelt sensor, would it be affected?
Just guessing on possible problems
