C63/C63S AMG
Dragy method
Old Oct 29, 2020 | 02:40 AM
SimMB's Avatar
C63S
Dragy method
What's your dragy method for 100-200. Only managed a 9.0 dead, race mode, auto. I think planting it from 30kmh was too much wheelspin.
Old Oct 29, 2020 | 08:17 AM
PayKoHan's Avatar
AMG C63S T-Model
best is from 70-80km/h in 3gear. i had with my t-model ~8,5s (best 8,3s)
Old Oct 29, 2020 | 09:04 AM
zipzap's Avatar
W205 C63s 2015
Dragy
3rd gear start TC off , manual mode.
depending on your level of mods will affect if you need the TC on or off, I keep the car in manual mode so if you have to peddle it for traction reasons when you floor it again it doesn’t down shift again, I also shift at 6000.
Old Oct 29, 2020 | 04:07 PM
Uaedragster's Avatar
C63S coupe 2020
For me personally i found auto to yield the best times on my stock coupe 2020 model. I got 8.8 flooring it from about 60km/h, TC fully off.
bad DA around 2700 ft, high humidity 29 degrees celcius.
i think with better weather it can do low 8.
I tried 10s of times with manual mode, shifting at 6000-6700, all >9.3. I suspect that might not be the case with the prefacelift transmission though and definitely on tuned cars which might benefit from different shifting points depending on the tuner’s powerband.
Old Nov 1, 2020 | 12:42 PM
Dany1337's Avatar
W205 C63 AMG
Sport+
ESP sport or off
Starting 3rd gear and let car shift from alone.
if you have tune on it shift at 6100-6500 into 4th.
Stock C63 non s: 8.5 sec
C63 non s with Stage 1: 6.8 sec
Old Nov 1, 2020 | 12:58 PM
PayKoHan's Avatar
AMG C63S T-Model
100-110 is incorrect. looks like a bridge start. 1G and 0,28s is not possible, maybe with 800ps+
100-110 should be around 0,4-0,45s
