False brake pad wear error
The sensor is normally a closed circuit and is opened when the sensor is "cut" by the disc rotor when it's exposed within the brake pad due to the pad being worn down to about 3 mm thickness.
Sensors are a relatively inexpensive part (even from the dealer) but do require the pad to be removed in order to replaced (which is also pretty easy ... see Mr. Google/YouTube for more info).
