C63/C63S AMG
recommended wheel sizes c63s Coupe
Old Nov 2, 2020 | 05:51 PM
Syndicate949's Avatar
2017 C63S Coupe Edition 1
I am looking for get some new wheels for my W205 Coupe. I see some guys are running 11 wide in the back and almost everyone running 20's all the way around. Wanted to get some feedback on setups. I believe I will get better performance on 19's but not sure how much better and if it's worth it...I may be wrong here. I am currently on KW HAS lowered approx 1.5" if that makes a difference.
Old Nov 9, 2020 | 09:46 AM
Enrique Borunda's Avatar
2017 C63 AMG COUPE
Also 19’s are way more comfortable than 20’s, specially if your roads are rough. I think OEMs rear are 10.5.
Old Nov 9, 2020 | 11:20 AM
untamedd's Avatar
2019 AMG GT R
depends on the tires you plan on getting imo. a 305 in the rear would ideally require a 11" wide rim in the back. can still go up to 295s on the stock 10.5 width (305 goes with 10.5 width too but its just not ideal)
off topic question since you are lowered..... do you know if it is possible to just lower the rear and keeping stock height on the front? dont know much about lowering so not sure if thats even possible
Old Nov 10, 2020 | 11:07 AM
deftronix's Avatar
17 C63S coupe
I have a set of 20" Klassen that are 10" F & 11.5" R - Went with the wrong front tires initially, car is too low and couldnt clear a 275/35/20 in the front (should have known better) even when adjusted to the highest setting on the H&R VTF's. Would probably fit fine at stock height. Purchased the wheels from another member here and he was lowered and didnt rub so the wheel widths will work.
Ordered another set that are 265/30/20-F 295/30/20-R but havent mounted them yet. Wanted some stretch so I can run low.
Old Dec 4, 2020 | 01:04 AM
Blaque Diamond Wheels's Avatar
Former Vendor of MBWorld
2014 S63
Definitely 20s if you're aiming for that sharp look. Although 19s aren't so bad especially if you're more after the comfort and function side.
Here, check out our customer's new wheel set up on his Edition 1. We hooked him up with some clean Frozen-Silver finished BD-11s in 20s
Just click on the images to view our full gallery on this project
***Mention You Are From The Forum For The Best Deals***
Check Out The*All NEW BD-F25
Phone: (818) 362-2300
E-Mail: Info@BlaqueDiamond.com
Website: BlaqueDiamond.com
Click here and visit our pages
IG: @BDWheels
FB: /BlaqueDiamondWheels
