C63/C63S AMG
C63 (non-S) 0-60 and 60-130 times
Old Dec 3, 2020 | 03:43 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
I just bought a Dragy and since we finally got some cooler weather in my area I thought I'd do some pulls to get some baseline numbers in optimal conditions. I have a 2017 C63 coupe (non-S) and it's bone stock down to the air filters. The only non-stock item on the car are the tires, which are a set of PS4S tires (275 front and 305 rear) with about 1,000 miles on them. The car was warmed up (not hot) and the tires were also warmed up. I do have a nearly full tank of gas.
With the current weather I really thought the car would perform better in the 60-130 but it seems to fall on its face in the upper RPM range, even though I short shifted around 6k RPM. There are no warning lights on and the car just came back from the dealer so I doubt there are any soft limp mode codes. I did get some wheel spin on the launch causing me to modulate the throttle so I'm sure the 0-60 time can be improved upon.
I've attached my best attempt. The 60-100 time was cut off of the picture but was 5.01s. Do these numbers seem right for a non-S coupe? The other 60-130 times were in the 12.3s range.
