C63/C63S AMG
Alignment problems solution
Old Dec 11, 2020 | 09:02 AM
speedpeddler's Avatar
2014 E63, Cobra replica, 68 Camaro, 66 Chevy II SS, Z4 BMW, Honda Element, Birel 125cc Shifter Kart.
So, twice now the inside of my front tires have worn down to the steel cords in less than 5K miles. First time I had the dealer align the car and they told me everything was within spec and made no changes. They showed me alignment sheet which showed everything within spec. For the record, I have a 35 year background in chassis and suspension setup from racing so I said no damn way it’s correct and any front end guy who looked at the tires would instantly know the camber is way off. They refused to acknowledge anything. Should have gone to a real alignment shop right then but didn’t. I am now going back for round two of this BS and wondering if anyone else has dealt with this and what they ended doing about it. I doubt MB is going to acknowledge anything but I believe they owe me for two sets of tires plus a refund on the alignment they didn’t do. I also put a camber gauge on it yesterday just for fun and the camber is way, way off. Any advice on how to politely get the dealer to acknowledge and fix this without creating a scene? PS: 2017 C63S.
Old Dec 11, 2020 | 10:18 AM
SLC63's Avatar
C63
Have you taken the car to a "real" alignment shop yet? I'd start there and have them provide a printout of the specs so you can compare it to the MB specs..
No way you should be blowing through tires every 5k miles.
Old Dec 11, 2020 | 10:41 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
The inside edge of my front tires wore out pretty fast as well, but not 5k miles fast. I put on a new set of tires and took it to an alignment shop that came highly recommended. He was able to get the car aligned, but advised the car has no camber adjustment from the factory (front or rear). Luckily, my camber was not bad so the alignment should hopefully resolve the problem.
I'd suggest taking the car to a good alignment shop in your area and having them take a look.
Old Dec 11, 2020 | 10:42 AM
Sea63s's Avatar
C63s AMG
How can a camber be off if c63s camber cannot be adjusted? Am I missing something?
Old Dec 11, 2020 | 10:44 AM
SJGetsome's Avatar
W205 C63 AMG Coupe
Something out of spec from when the car was assembled or maybe a result of lowering the car? Other than that, I'm not sure either.
Old Dec 11, 2020 | 11:16 AM
mstraka's Avatar
amg C63s
Lots of info on this subject/problem in previous postings.
Old Dec 11, 2020 | 12:04 PM
Interesting. I did not know there is no camber adjustment on these cars. I spoke with an acquaintance that used to work at the dealer and he mentioned some kind of replacement bolt or something is available to correct this. Anyone heard of that? At this point, if there is no fix from MB this car is gone. Very disappointed as I only have 25k miles on the car and it’s my favorite AMG and I’ve had five starting with an SL 55, S55 coupe, E55, E63 and now this C63 S coupe.
Old Dec 11, 2020 | 02:41 PM
superswiss's Avatar
2019 C63CS
There is no camber or caster adjustment on these cars. The only thing they can adjust is toe, so your MB dealer didn't try to pull one over on you. Toe was probably in spec, but they can't do anything about anything else. Have you inspected your suspension to see if something is bent? If you want to adjust camber you need to get aftermarket adjustable control arms. The front camber on these cars is quite aggressive, so camber wear is normal, but going down to the belts in only 5k miles is not. I did have the same issue at 10k miles, and had the car aligned and replaced all 4 tires with the PS4S. Front toe on both wheels was out of spec. Haven't noticed an issue so far after 8k miles.
Old Dec 14, 2020 | 12:39 AM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Yes, the often quoted reassuring “FULL FRONT & REAR WHEEL ALIGNMENT” is only TOE (directional) adjustment!
OEM there is no Camber or Caster to resolve costly, premature edge tire wear by allowing to adjust tire contact angles, spread load more evenly. Excess edge load can also lead to higher impact, ruptured side walls.
IT IS NEW CAR INDUSTRIES BEST KEPT SECRET! IT IS ALL TO DO WITH COST CUTTING AND EVER INCREASING SPEED OF AUTO ASSEMBLY LINES.
KMAC took on the role and has the experience of “resolving OEM suspension short comings since 1964”. World’s Largest Range adjustable bushings, Arms and Strut Tops, AUDI to VOLVO.
FOR THE C63 / S “A TOTAL SYSTEM”:
INCLUDING '3' ALTERNATE CAMBER (AND CASTER) ADJUSTER KITS FOR FRONT:
1. #503316-2 J at $380 (LESS THAN THE COST OF ONE HIGH PERFORMANCE TIRE) Offers up to 1.5 degrees (+ -) Camber and Caster adjustment.
More than enough to fully resolve most costly, premature edge tire wear issues.
Simply replaces upper arm, inner bushings. No need for arm removal – bush extraction tool included. Along with not having the concern of replacing “factory arms” with welded, fabricated arms!
2. #503316-3 N – COMPLETE "UPPER ARM REPLACEMENT. Up to 2 degrees (+ -) Camber (and Caster) adjustable. Security, peace of mind of high strength forged alloy same as OEM – not welded, fabricated (Camber only) arms.
3. #503316 K $480. “LOWER ARM” kit up to 1.5 degrees (+ -) degrees Camber (and Caster). Replacing also the ‘4’ front highest wearing bushings at the same time.
Adjusting lower arms, retains clearance top of tire to outer fender when wanting to reduce inner edge wear (or when adjusting for “extra negative Camber” also increases track width!).
Other advantage of this lower arm kit is the forward facing thrust arm (Caster bushings) are Mono ball / 2 Axis. Deleting the OEM soft rubber, oil and air voided bushings, yet still allowing arms to travel through their required arc without binding, locking up.
The result is significant improvement to brake and steering response. There are available 2 Axis / spherical bearing bushings but in all out competition soon pound out. KMAC saw the need for a design breakthrough, a new generation and developed the above a design having “two and a half times” the load bearing, impact area.
NOTE: Combination of #1 or #2 with #3 provides “TRACK DAYS” – the adjustability to hit those corner apexes every time and go deeper into the corners with improved traction and brake response. In the pursuit of “front row of the grid lap times.
FOR THE REAR SUSPENSION:
4. #502226 K $480 Lower Arm Up to 1.5 degrees (+ -) Camber (and extra Toe) adjustable bushings. Like front, precise single wrench adjustment accurate under load, direct on alignment rack. Retaining top of tire to outer fender clearance when adjusting to reduce inner edge wear.
5. #502226 -3 M $595 Upper Camber turnbuckle adjustable arms (including extra Toe adjustment to compensate).
Unlike other brands not soft extruded aluminum but OEM design high strength forged alloy.
6. #502628 K $480 UPRATED REAR MULTI LINK ARMS (6) – Bushing kit
Less twitch, flex, loss of traction – Especially when applying power to lane change / overtake.
OUR LONG TERM EXPERIENCE IN THE INDUSTRY SHOWS WITH KMAC BEING THE ACTUAL “INVENTORS / PATENTEE’S” OF ALL THE IMPORTANT DESIGN BREAKTHROUGHS:
· Single wrench adjustment system (Precise adjustment without the need for time consuming bush removal).
· Sliding ball joint adjustment system (now the industry standard).
· Ability to adjust Mercedes (Strut models) Upper adjustable mounts from engine bay (without time consuming need for strut removal)
