C63/C63S AMG
Help... This car just doesn't wanna point straight.
Old Jan 12, 2021 | 03:26 PM
dezau44's Avatar
16' C63 Sedan
Old Jan 13, 2021 | 03:18 PM
AlexZTuned's Avatar
2017 Porsche 911 C4
Looks like you need R-compounds and less aggression with the throttle on mid corner.
I applaud you for Auto-X’ing this car, probably the worst case scenario for these heavy torque monsters.
Old Jan 13, 2021 | 03:54 PM
Cylinder Head's Avatar
'19 E63S, ‘16 CLS63 RIP, '09 E63 Gone, '06 M5 Gone, '97 Supra TT Gone
Way better off letting TC do its thing unless you're Chris Harris
Old Jan 13, 2021 | 08:02 PM
elitex's Avatar
2020 C63S Coupe, 2021 Bmw X5M Competition
Try sport traction or master traction mode rather than just turning it off. Try to put some heat in those tires before going in.
Old Jan 14, 2021 | 09:32 AM
velosdesignwerks's Avatar
Former Vendor of MBWorld
Mercedes C63S AMG (W205)
Can you tell me more about your setup? I see the original wheels, what tires are you running?
Ive AutoX'd my C63S also and was only able to get decent traction by being light on the throttle and doing a little burnout to heat up the rears. I run PS4S tires.
With the start to that track being a direct left turn i assume throttle control is going to be your best friend.
Old Jan 14, 2021 | 06:17 PM
dezau44's Avatar
16' C63 Sedan
I came from campaigning a Camaro SS 1LE, the way the torque just surges from the M177 is nothing like the LT1.
I could get R-Comps, but that'd mean getting another set of wheels and that puts me out of class.
I've tried that, it intervenes too much. Tire heat has nothing to do with this.
I'm running stock wheels (class rules), but 275/35-18 square, the tires are Falkens RT660 (these are the quickest Auto-X now, depending on how NanKang CR-1 or Kuhmo V730 performs. They stopped making RE-71Rs a year ago and Rival S 1.5 are just too expensive.
I've also come to realize driving the C63 would require a more delicate control than the Camaro 1LEs, this car is overweight and under-tired. I might try 315/30-18 in the rears when the rears worn out.
I tried the car out with TC first but with it On, and Sport, it just intervenes too much. I tried all 3 in my first event, but my times were pretty close. I think the trick is to slightly under-drive the car a bit. Maybe Race mode in the S-es help.
At least the gearing is great for Auto-X, so we've got that going for us.
Old Jan 14, 2021 | 07:07 PM
superswiss's Avatar
2019 C63CS
A couple of thoughts. The sedan is definitely under-tired, and doesn't have a reworked rear axle like the coupe with a wider track. Since you have the non-S, you also don't have the electronic locking differential, which makes a difference especially for Auto X and track driving. Since you have a 2016 you are also limited to TC on, sport or off and that's it. You don't have the new AMG DYNAMICS system. The 2019+ S models have the 9-stage traction control straight from the GT3 so one can dial in just enough intervention to get around the course w/o going sideways constantly, but also not being bogged down completely. You would have 9 levels to dial it in precisely and could even adjust from corner to corner.
Old Jan 14, 2021 | 07:13 PM
dezau44's Avatar
16' C63 Sedan
Good points. I thought about whether the e-diff would help. I imagined the Mechanical diff wouldn't completely suck. I thought wrong...
Old Jan 14, 2021 | 07:20 PM
superswiss's Avatar
2019 C63CS
Yeah, the mechanical LSD primarily avoids the infamous one wheel spin, but it needs one wheel to have a certain amount of slip before the locking mechanism does anything. The e-diff constantly monitors many sensors such as steering angle, acceleration, cornering forces, perceived amount of traction etc. and precisely calculates how much to lock and how much torque to send to each rear wheel which is known as torque vectoring.
Old Jan 14, 2021 | 07:27 PM
dezau44's Avatar
16' C63 Sedan
Yea. The 1LE puts down power way better. Partly probably due to wider tires, mag ride and the fancy eDiff.
