How dangerous are our cars at high speeds?
I was driving and towing customer’s cars on the streets of Philadelphia at age 12! I was helping my father push or tow their cars to his auto shop in the snow when they wouldn’t start or just died for some reason. Sometimes at night. I’m 72 now. I’ve driven most types of vehicles in most every weather conditions on every type of road. And through all that? Drivers scare me the most.
High speed accidents are extremely rare. Most accidents on the autobahn happen due to not recognizing traffic jams ahead...
Maybe an american driver feels more comfortable on an empty Autobahn:
The point is: The C63S with stock 19" and Michelin PSS runs smooth and stable as hell at 180 mph. Except - the fuel capacity is way to low. At a steady 112 mph cruise, that car takes (in a station wagon), all you get is 13.5 mpg...
Yeah, I'm in Biloxi and driving in New Orleans is like being on a race track with no rules. Along with the extremely bad roads over there I make sure and drive my SUV every time I go that way.
C63S Edition 1 coupe in Mexico. Mirroring a motorcycle on the highway, up to 180mph. Felt pretty light past 165mph. Braking was very very scary at that speed. Car would shimmy a bit from side to side. Edition 1 = carbon ceramic brakes. Allegedly.
Yeah I actually had that exactly same experience with mine (coupe) when braking real hard at those speeds with suspension in Comfort. It's almost like the car would float from side to side.
On a separate note, a 911 C4S gets "light" around 120 mph on throttle. But then "hunkers down" around 130 mph and feels incredibly solid all the way to 170mph. It's interesting how aerodynamics work at different speeds.
obviously he wanted to know .. as an enthusiast and onwer
this is why i dont post on here anymore ! B** A** bully's
hey bro !
Track day as a rookie and 3 laps
Mich 4s - I hit 109 straight away and felt planted
You need to track the car and find out ! we have no way to tell you how your car reacts.
to many factors, weather , Road conditions , etc , car setup , style of driving
I've had other dreams in which I've reached the same speeds in other vehicles (at least 2), and the aerodynamics made it feel planted firmly to the road (large rear deck wings). Very stable, no shimmying with braking.
Any mods on yours that pooped your suspension geometry such as spacers, aftermarket wheels, non-factory size tires, lower suspension etc.? Also, make sure your alignment is good. Just had mine aligned last week for the third time, and I can tell that it drives better again. Not that it drove bad before, but the front end today was more communicative. My toe was slightly out again. I do have to say I was not a fan of the OEM PSS tires at all. Much better with the PS4S and make sure you use proper tire pressure. If too high it will also start to swim around. 33 psi front and 32 psi rear if you are by yourself.
I also experience this bizarre WOBBLE when braking hard at high speed.
Mine's a pfl. But it seems fl owners are feeling this too.
The best way to explain this is the rear is almost swaying from side to side as you momentarily brake hard at over 100mph.
Accelerate very hard at highway speed and hit around 100mph/160km/h........
If you suddenly hit the anchors after accelerating at this speed, this car will sort of lift up in the rear and wobble around for a brief moment until it regains itself.......
For me my car is coupe stage 1 tune 600hp
Comfort mode
Full tank gas
Myself and 1 passenger
OEM red brakes, pads and rotors
I'm thinking brake bias is playing a role combined with comfort mode suspension settings being spongy?
Are you guys experiencing this only with suspension in comfort?
There's also no fixed brake bias. This car has EBD (Electronic brakeforce distribution). It dynamically sends brakeforce to the wheels that can slow down the car based on individual wheel grip. This can cause the car to move around if not all wheels have equal traction, but ESP and ABS will compensate.
However, aside from that, I wouldn't do this with the suspension in Comfort. Comfort mode can get floaty at high speed and quick load transfers at least in the FL. It's tuned for a more subtle ride not for handling. I keep it at least in Sport on the highway to handle quick lane changes etc., unless I'm just relaxing and cruising along.
