Steering clunk at low speeds or when stopped
Did a bunch of searching and saw answers ranging from an airbag bracket catching to a steering knuckle, to a whole steering rack needing replacement.
Interestingly, I believe MB lists the rack as non serviceable, but you can get tie rods for cheap that install just fine.
Admittedly I haven’t gotten the car in the air yet to check for something obvious like a wheel bearing, but, the noise sounds way closer to the steering column, just around the firewall, rather than down at the wheel hub.
Figured I would share in case anyone else has experienced this.
Luckily I have a good independent shop near me and they did the whole job for $350. Beats adding a zero do that to have MB tell me the rack isn’t serviceable.
