HELP! Car intermittent hiccup/stutter during idle, NO CEL
So after a long hard drive today, I noticed that the car will intermittently stutter at idle. The stutter is very subtle, however, definitely noticeable. It would come on every 3-10 seconds, with a small stutter, and then go away. I do not observe RPM's gauge change, but I can definitely feel/hear the stutter. This stutter only appears in comfort mode and at idle (when car is stationary, in P, N or D). Currently car is completely fine when driven hard or at high RPM's. No CEL. From my online research, it seems like this can be caused by bad engine mounts, bad spark plugs, dirty MAF, among other scary/expensive items. A little bit of background on my car:
- Car is currently at 32k km, out of warranty as of April, 2020.
- Always driven hard (copious hard accelerations, always driven in sport+ mode, numerous launch controls), but I keep up on the service. Dealer services done on schedule, as well as additional oil changes performed at indy shop between Service A/B's (~6k km oil changes).
- Fresh Service B done 300 km ago, consisting of engine oil, transmission fluid and clutch gear fluid, gauge cluster update and cabin air filter. Opted out of stock engine air filters, spark plug change and brake fluid flush (will upgrade to higher temp fluid soon).
- K&N engine air filters installed right after Service B.
- Car completely stock otherwise.
From what I've read, it seems that the oil on K&N filters can damage the MAF. Am I starting to see the beginnings of a failed MAF? Should I take the car to the dealer to ask for their diagnosis, or should I take it to an indy shop? Unfortunately not much online resource on this particular model of AMG as it is a GTS. But, hopefully you guys can help since the engine is very similar. Posted on the gts forum but again, not much activity over there. :/
Thank you in advance!
I've yet to hear of any M177's getting the walnut blast treatment to fix any issues - if anything, it's been sensors failing prematurely that's the issue.
