C63AMG W205 Juddering and Jerky under Acceleration
Question is.... Could the TCU cause this issue? Guess well find out. I have spoken to the sales manager and said if this doesnt get fixed you guys are buying my car back and I will go elsewhere.
If its the TCU get them to change it and test it, if it works thumbs up, if it doesn’t let them have it back. I didn’t want to give mine up without trying but there is only so much trying one man can do.
Good luck 👍
Good luck 👍
I will be back once i source another problem free beast.
Hope you all get your problems fixed and have many years of good driving ahead of you.
be safe 👍
be safe 👍
How wide are your rims with the 295's? I have a bent rim I need to replace and still have the 265's on 10.5 rims.
I replaced my cat's, not get rid of them. Two reasons, engineers usually design and test to work within some parameter, and the cats are an attempt to delay global warming. Usually when you go outside those design parameters something breaks (o-rings and shuttles, larger wheels and torque, etc). Mercedes has been at this a long time and has stuffed 469 hp in a very nice package whereas my 67 Goat is only 335 and I can sleep in the engine bay, but I digress. Better call to see if my parts are in and get to work.
Did you replace your conductor plate yourself? Is it a DIY drive jobby? I still think it's the gearbox playing up but all that have looked at it have said it is fine.
I will add that my car requires a little juice on the pedal to get in moving once put in drive but will sometimes do so on its own. When it does move on its own it usually is somewhat jerky off the bat. I experience that juddering and jerking from 1st to 2nd gear with light acceleration and sometimes at mid level acceleration in other gears. The issue that caused the second check engine light to come on today may be related to these issues and I will keep the forum updated if I find a solution.
I've had the car for under 6 months and these issues are worrying to say the least. I hope my dealership can get this fixed or Mercedes steps up and gets to the bottom of this issue as it really ruins the ownership experience. I mean hell after 24 hours of having the car and a check engine light comes on? Will keep everyone updated.
Annoying that i've had to deal with it all year but at least it is now fixed. Hopefully this helps some of you.
I would pay for this ahead of changing all the parts that I have had to. It would have saved a lot of time and money.
I guess my lesson learnt is if you suspect a gear box issue get it’s oil and filter changed first and go from there.
Happy days 👊
