C63/C63S AMG
🌡Transmission temp rise before Oil temp? C63S
Old May 16, 2021 | 11:40 AM
George_1992's Avatar
C63 S Coupe
Trans hit about 92c/197f in Sport mode and it rose a bit higher than my engine oil temp........... which I thought was odd because I usually only see the engine oil temp rise first with the trans temp trailing behind.
It never got higher than this and after driving normal the temps settled down.
Have you ever seen your transmission temperature rise first......... with your engine oil temps trailing behind?
Trying to mentally prepare myself for another big repair bill 😒😒😒
Thanks...
George Lisciandro
Old May 16, 2021 | 12:35 PM
djprov431's Avatar
2021 C63S Coupe
Thanks...
George Lisciandro
I would agree that I am always waiting on my transmission temp to warm up after the engine oil - it has 100% of the time lagged behind from a cold start (which makes sense). Was your experience from a cold start? Additionally, I usually wait for both temps to turn white (warmed up) prior to taking it out of comfort mode most times, however If I do put it to another mode it would be sport, and I drive it respectfully until warmed.
Old May 16, 2021 | 12:42 PM
C63 S Coupe
Originally Posted by djprov431
I would agree that I am always waiting on my transmission temp to warm up after the engine oil - it has 100% of the time lagged behind from a cold start (which makes sense). Was your experience from a cold start? Additionally, I always wait for both temps to turn white (warmed up) prior to taking it out of comfort mode most times. If I do put it to another mode it would be sport, and I drive it respectfully until warmed.
Yes sir. From a cold start but instead of keeping it in Comfort mode until it warmed up I set off in Sport mode and drove it gently until it got warm......... and as it was slowly warming up I noticed the trans temp always about 2c degrees ahead of engine oil temp this time 🤔🤔🤔
Old May 16, 2021 | 01:34 PM
skratch77's Avatar
2005 E55
Check coolant for leaks and see if you have any in the res between the turbos.
Old Aug 4, 2022 | 03:07 PM
Jimmy_c63s's Avatar
Thanks...
George Lisciandro
Pretty sure I seen mine do that as well in the past if I start the car in SPORT mode after it's been parked less than 4 hours 🤷‍♀️
Old Aug 4, 2022 | 05:44 PM
raphman's Avatar
'16 C63s
My trans always gets up to normal temps before the engine oil... never seemed to be an issue though. Neither temp gets unusually high, even with spirited driving in the Texas summer.
Old Aug 4, 2022 | 09:01 PM
noremaC's Avatar
17 C63S Coupe PTG1000
Trans always beats engine to operating temp. Even highly modified with CSF’s 3 piece coolers, PTG turbos etc etc. Modalworks split trans cooling kit and upgraded trans thermostat arrive this week, so not sure how that’s going to change the dynamic once installed - but I’ll report back.
By the way, even with the supporting cooling mods I have in North Carolina heat, I still hit upper 190’s, even 200+ F in trans temps when doing back to back WOT pulls. It’s about how fast the cooling system reduces the heat soak to optimal operating temps is why you upgrade to higher performing products. Now, with the split/divorced trans cooling system from modalworks, that may bring operating temps down and stabilize those numbers even more. We will soon.
Old Aug 4, 2022 | 11:50 PM
C63 S Coupe
yeah that's what happens on mine too...... thanks jim
great that really helps ease my mind!!
thanks mate please let us know how the split trans cooler goes after testing 🙏🙏🙏
very lucky to hear from someone with a lot of experience
Old Aug 17, 2022 | 10:14 AM
noremaC's Avatar
@George_1992 - following up, after having the split cooling system installed, I confidently say that this thing is the real deal. I saw my cruising trans temp lower 30*F. After doing back-to-back 60-130 hits, I saw a max temp of 185*F. And you have to remember, I am running big turbos with higher boost than stock. Before the cooler, I would get above 200*F with just a few pulls. And the car would pull power.
If you are modded, and have heat soak challenges, this upgrade is a no-brainer.
Old Aug 20, 2022 | 12:45 AM
C63 S Coupe
This is what I needed to hear!!! Going to order mine did you have to drain the full cooling system to install the split trans cooler? I was actually going to order the Modalworks 3-piece cooler for M177 and the split trans cooler too. Do you think thats overkill? Only running 600hp stage 1 tune with very minor mods here but heatsoak killing my car after 2 WOT pulls car is so sluggish!!!......
Ps thanks norm for reporting back bud
George
Old Aug 20, 2022 | 10:52 AM
noremaC's Avatar
George
you do not have to drain the full system, although I had the cooling system flushed and also did a trans fluid service at the same time. I’d recommend doing both, with the 3 piece kit as a higher priority, followed by the split trans kit. You might as well do both while you’re in there. You will be amazed how upgrading the cooling affects the drivability, being able to do back to back hits without a drop in power.
