Airbag Light after removing and reinstalling Steering Wheel
I installed a sterring wheel cover on the C63, so I removed the steering wheel. I disconnected the battery, waited for a while, then I removed the airbag, unplugged every connector very carefully, and then removed the wheel.
After installing the steering wheel cover, I installed the steering wheel in the same reverse process. But then the light on the display says "Airbag Front Right Malfunction, service required". Didn't go away after several miles, so how can I erase the message?
Thank you very much.
