New C63s Owner To Be - I Have A Few Questions
So, while I have the HUD I pay very little attention to it. Most when driving at night, if et all.
FWIW, below is how I have it configured for most of my driving, but I can quickly change the left and right area with the touchpad on the steering wheel for different situations, like bringing up nav and trip information on a longer drive for example, but here's my thinking:
- No useless (to me) speedometer taking up half of the instrument cluster. Just a large, easy to read digital readout for the speed that only takes a quick glance for my brain to register instead of trying to read a needle.
- Above that in equally large font the current gear. Kind of a neat thing is that it shows the gear sequence left and right of the current gear in manual mode, and graying out the next higher or next lower gear if the current rpm doesn't allow it to be selected. One less reason to really need to look at the rpms in conjunction with the shift lights mentioned earlier.
- Around it is the rev counter front and center, so all the key information is displayed right in the center of the cluster.
- Then on the right I have all the relevant temperatures, complete with color coding of the powertrain and tires as they get hot in the canyons. The tire temps are mainly useful to know if they have enough heat in them for traction. The tire pressure is just kind of a piece of mind to know if there is loss of air after driving over something. I have a bit of a history of getting nails and screws in my tires, but once everything is up to temperature I can replace the right part with trip information or the navigation map for example.
- The left side can display all kinds of info. The one I usually use is one of the AMG Performance displays with boost gauge and a summary of how the car is currently setup. Since I frequently change drive mode settings I like seeing the current setup, but if I'm navigating I might replace it with the turn-by-turn instructions or bring up media information if I'm listing to music.
