W205 e-LSD - wheel slip during low speed maneuvering
Starting with MY2019 both the C63 and C63S have an electronic locking differential. Prior to that the C63 non-S had a mechanical LSD. Both are locking differentials, though. The e-diff can lock a 100% at any speed, so your situation is generally not an issue. I've driven over such driveways and I've also parked with one wheel in the sand. The wheel might spin a bit initially, but it quickly locks the differential to send torque to the wheel with traction. The C63's locking differential also torque vectors, but it does it by varying the locking ratio and with the help of the brakes if necessary. It only has one clutch to fully lock both half shafts together.
