Wavetrac Limited Slip Differential on C63 AMG W205
I am searching how to upgrade my C63 AMG Coupé W205 (2017) regarding traction and performance improvement. In fact, i want to maximize traction and minimize wheelspin by evenly distributing power to the rear wheels. The objectif is even to have great perfomance in drag and road racing, as well as in normal street user.
My car is not the C63s but the C63 AMG. I haven't got the electronic differential which is a standard item on the C63s.
Electronic Limited Slip differential for the C63S that can dynamically adjust the wheel spin. My standard C63 has a mechanical differential which is a fixed ratio I believe.
A lot of professional tell me that i have to change the original differential by a wavetrack or equivalent but have a doubt.
Appreciate all your input and help.
Many thanks in advance
http://www.wavetrac.net/technical.htm
The electronic locking differential in the S doesn't have these issues, because its locking ratio is electronically controlled and fully variable between open and full lock, so if one wheel has no traction all torque goes to the other wheel with the diff fully locked. It's also much faster acting, because it doesn't require wheel slip before it starts locking. It monitors several sensors such as throttle input, steering angle, acceleration, measured grip etc. and calculates the appropriate locking ratio and even locks proactively. For example during Race start it locks before the car even starts moving, so you have full traction from the get go. No mechanical replacement LSD can give you that, but LSDs such as Wavetrac work better in low friction scenarios.
I have find it for W204 C63 but not for W205 C63 car.
If someone can give me the right reference for my car and a good vendor to buy it.
Regards,
Olivier.
Regards,
Olivier.
