C63/C63S AMG
Diagnostics - New Engine ECU?
Old Apr 26, 2022 | 02:56 PM
MH97's Avatar
Mercedes C63 AMG W205 (66)
Evening, I recently bought a 2017 C63, it went into ‘limp’ mode and engine light came on when fiddling with the cruise control and limiter, not sure that was at all related to it going into limp mode though. The engine light did go off the next day and stayed off since. Ran diagnostics on the car at a local MB specialist to investigate. They found an issue with the starter motor/battery, and an issue with torque control within the control unit. They recommended an ECU software update to be carried out and diagnostics re-run to see the response.
If the fault codes remain the same their thought is the car will require new Engine ECU (this came up on the diagnostics software). Anyone have any thoughts or had anything similar?
Cheers
