C63/C63S AMG
FS: Otis Inc 12mm spacers with lug bolt (5x112 bolt pattern with a 66.56 center bore)
Old Jul 22, 2022 | 05:39 PM
AMG82's Avatar
2020 C63s Coupe
SOLD!
Selling almost new Otis Inc 12mm spacer set (two spacers) with original Otis Inc 40mm shank length extended lug bolts (qty 10).
Spacer spec: 5x112 bolt pattern with a 66.56 center bore
Extended lug bolts spec: M14x1.5x40, R14 Ball Seat, Hex 17 (compatible if your Benz comes with 27mm factory lug bolt)
These spacers are made in USA with Alcoa 6061T6 billet aluminum.
https://www.otisincla.com/collection.../products/3314
I purchased this directly from Otis store to pair it with wider 265/35/19 front tires on the Coupe, but it made my wheel stick out little bit more than expected.
I ended up replacing them with 5mm spacers.
These 12mm spacers were on my car for a week and has less than 50 driving miles on it.
Price: $95 shipped to contiguous US (accept Paypal)
By the way, some people reported that 12mm spacers from H&R and other companies such as ECS do not fit well on W205 C63 cars because factory hub lip is too long, which makes normal spacer not to sit flush on the hub.
Due to this, most people go with either 15mm or 18mm spacers.
I measured factory hub lip on my C63s Coupe, and it sticks out about 12mm.
This 12mm spacer from Otis has hub lip clearance of about 14.5mm so it clears factory hub lip no problem.
Old Jul 25, 2022 | 01:38 PM
AMG82's Avatar
2020 C63s Coupe
Bump.
Old Jul 28, 2022 | 11:22 PM
AMG82's Avatar
2020 C63s Coupe
Price reduced!
