C63/C63S AMG
Loss of boost after 4500rpm
Old Aug 26, 2022 | 01:53 PM
2019_c63s's Avatar
C63s Coupe, AMG GT R and 458 Italia
I have been facing this problem and have taken the car to the biggest Mercedes Service in Turkey 3 times but still got no result. No error seems to appear when they plug it into the computer. Is anyone familiar with this issue? The car has got just under 6000km done with the engine run in period done as advised.
Old Aug 26, 2022 | 05:50 PM
SJGetsome's Avatar
W205 C63 AMG Coupe
It seems you may be in a soft limp mode. The average code scanner will not detect a soft limp mode code and you would need to take it somewhere that has dealership level diagnostics (I believe the system is Xentry). See if the shop you took your car to has that capability.
Old Aug 27, 2022 | 03:46 AM
Iridium.C63s's Avatar
16' C63s, 22' RAM 1500
Check your exhaust flaps… they put your car in limp mode with no check engine light.
Old Aug 27, 2022 | 05:04 AM
Jimmy_c63s's Avatar
Exhaust flaps
Definitely sounds like soft limp mode due to exhaust flaps being stuck or the flap motor malfunctioning. First step is to grease all of them with WD40 or a bit of copper grease.
It's an annoying issue which I still face from time to time simply because I still want to retain the ability to use quiet mode.
Going to look at upgrading to an Akrapovic setup some day if I can find one for a decent price.
