C63/C63S AMG
Electronic rear axle differential lock inoperative
Old May 2, 2024 | 03:24 AM
EVL63S's Avatar
2017 c63s coupe
Originally Posted by Jimmy_c63s
Don't stress mate
Turn car off for a bit, start her up again see if the message is still there. If not, drive it normally.
1. If the message comes up again, get the drivetrain software updated.
2. If that fails, it's the actuator (not expensive & you can change it yourself without jacking up the car).
3. If you get the message again after the actuator is replaced it's time for a new diff/rebuild but this is rare. As my AMG tech Allen said "90% of the time it's the actuator.
Hi all, having the diff error issue atm, can anyone confirm if this is the actuator shown in Jimmy's pic above? cheers
https://www.mboemparts.com/oem-parts...tor-2059060302
Old Jul 10, 2024 | 02:08 AM
AMGC63s user's Avatar
mercedece AMG C63s 2017
Any one tried the actuator solution for this message and worked it will help me because i got the message
Old Jul 10, 2024 | 02:52 AM
EVL63S's Avatar
2017 c63s coupe
I recently had to get a new diff, software updates didn't fix it, actuator was tested and appeared to be working normally, so consensus between Merc dealer and a Merc specialist private workshop was diff's f*cked. Apparently work clutches/packs is fairly common in these, common enough that Merc Aus has racks of rebuilt diff on shelves ready to go. $10,000 aud later and i have a new/recon'd diff an no further error codes. Thankfully i had 3rd party extended warranty that covered it.
Old Dec 3, 2024 | 03:50 PM
PRESAMG's Avatar
C63 S
Revisiting this because I have spent $3000 US replacing wiring, Actuator, and Updating software, code came right back after 10 minute drive. I am at a loss. I do not want to put anymore into the car but I can't sell it in good conscious knowing it is there. Seems like replacing entire Diff is only option?
Old Dec 6, 2024 | 12:15 AM
EVL63S's Avatar
2017 c63s coupe
Hey mate. If a software update, and the actuator has been tested or replaced and you still get the error, yeah most probably its your diff on the way out. As i said its a common enough issue that Mercedes stocks rebuilt diffs for c63s's.
If you dont have warranty i'd consider going a wavetrac or similar aftermarket diff than another oem. will probably work out cheaper and will be way better/stronger.
Old Feb 12, 2026 | 12:45 PM
C60 Free's Avatar
C63 MY15
Those that have looked at software - does anyone have a definitive version for the relevant modules that means the update has been applied?
Also - for the actuator - does anyone know the specific bolt torque figures for the actuator if replacing it?
I am in two minds to change the actuator for a pretty rare 'inoperational' message that mainly triggers are very low speed doing reverse manouvers.
Old Feb 12, 2026 | 02:41 PM
  #32
C63s_Jack's Avatar
AMG C63s Coupe
Crazy things i have to read here
Lots of money burning ?
Update/new Actuator/ new diff ???
Sounds like nobody knows anything for sure, but we'll do something eventually.
Exists a techical description of this diff ?
I took a fast technical advice to the e-diff (C63s Coupe)
-> The differential works with multi-plate clutches and 2 pressure rings.
First ( its allways the same) use Xentry for diagnostic ( read errors & testing) .
If control devices ok, actuator ok the only what remains is the mechanical/ clutch issue in my mind.
This things can usually be repaired - no new 5.000$ diff needed.
Notice: All 50.000 km 31.000 mi / 3 Years new diff oil with MB spec 235.61 ( Castrol Transmax Limited Slip LL 75W- 140). ~ 1.2 Litre.
Old Feb 13, 2026 | 07:44 AM
  #33
C60 Free's Avatar
C63 MY15
Yes I am trying to find out for sure which version of the control module(s) mean you have an update or not.
Unfortunately that seems difficult to find.
Old Feb 13, 2026 | 09:08 AM
  #34
C63s_Jack's Avatar
AMG C63s Coupe
delete/twice
Old Feb 13, 2026 | 09:10 AM
  #35
C63s_Jack's Avatar
AMG C63s Coupe
SW Update for modul ?
If hardware is worn no update helps.
Thats not a computer or cellphone thats a pice of oily iron.
If you dont know the specific MB torque NM - i think possibly you can use the tightening torque table for screws (standard thread metric „M“ )
Old Feb 16, 2026 | 04:06 AM
  #36
C60 Free's Avatar
C63 MY15
Thanks for the tip on the torque settings.
Agreed that if it's a mechanical failure of the diff itself then no software will help - however the error message for me appears in very specific circumstances. I have no reason to believe that the diff is faulty from a mechanical perspective as it's quite specific manouvers that trigger the error.
I am hoping to find out the exact software module version with the update if possible
Old Feb 16, 2026 | 05:34 AM
  #37
C63s_Jack's Avatar
AMG C63s Coupe
okay - i think for this you need the Diag. SW from MB
called Xentry. Go to MB Service Shop and let a Update doing.
Or did i misunderstand you ?
Old Feb 16, 2026 | 05:55 AM
  #38
trigital's Avatar
W213 All-terrain
ediff it's the name of the module...but this will not help you at all if you do not start from the begining.
1 - Make a diagnose - diagnose is the process from where you have to check step by step as the program instruct ( Xentry is the name of the program ) starting from the error code, where the error code is not relevant for any parts exchange but is mandatory for step by step diag.
2 - ...depends of the last step of the diag.
Old Feb 16, 2026 | 06:47 AM
  #39
C63s_Jack's Avatar
AMG C63s Coupe
3. Xentry tells SW vers. on modul & tells you if newer SW version exist.
Old Feb 16, 2026 | 07:39 AM
  #40
MAYBACH W220's Avatar
W220
Well you don't want to go to far while the rear diff is locked you may damage the transmission permanently I would have to see it in person to know more
Old Feb 16, 2026 | 02:39 PM
  #41
C60 Free's Avatar
C63 MY15
My diff isn’t locked or broken - but I do suspect a software issue which multiple people report.
I have Xentry and can read all modules - so I want to check the version before going to MB
I don’t think I can tell if there is a update for the module because the version I have is slightly older
Old Feb 16, 2026 | 02:43 PM
  #42
trigital's Avatar
W213 All-terrain
Xentry is more than a fault code reader or Variant reader.
You can click on the Fault Code and then from right bottom corner you can press "Test" or "Continue"...as you may have only a broken wire or some water ingress into the connector
Old Feb 16, 2026 | 02:49 PM
  #43
C60 Free's Avatar
C63 MY15
Thanks, do you know if Xentry can apply updates?
I assume the updates are pulled from MB’s server rather than bundled into Xentry
thanks
Old Feb 16, 2026 | 02:52 PM
  #44
trigital's Avatar
W213 All-terrain
Only legit Xentry can do updates
Do the step by step diagnosis, there is no sense to update something defective.
Old Feb 16, 2026 | 03:32 PM
  #45
C60 Free's Avatar
C63 MY15
thanks, I will report back at the weekend with my findings.
And just after I posted I found that you do need legit Xentry to perform an update. Understandable really, and I’m not averse to the dealer updating it.
