C63 Traction & New Tires?
I'm a new C63 wagon (2017) driver. So far so good
But today for the first time I experienced wet roads.. oh boy. I was driving in comfort mode, stopped then turning 90degree on an intersection and the car was oversteering a lot... was drifting for a moment.
Was quite surprised by the lack of traction with such low gas pedal push. IDK if there was some oil or why was the road so slippery, but it caught me by surprise.
Reading some of the posts here I should probably upgrade to wider tires for better traction on wet roads? My current tires: Michelin Pilot super sport 265/35/19 and 245/35/19
Rear to 285/35/19 Michelin Pilot Sport 4S? How about front tires?
Thanks!
. Taking control of the transmission and short shift to reduce wheel torque is one strategy. Pretty much wanna go quickly into 2nd gear, although the PFL already starts in 2nd gear when in Comfort mode. The FL has a Slippery mode now, which reduces torque and throttle response to make it less likely to spin out in the wet. Never needed to use it, though. Drifting is fun
. The ESP should keep you from going out in a 360, though.
PFL = pre-facelift
FL = facelift
