Iridium.C63s
close
- Join DateAug 2021
- LocationSoCal
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive16' C63s, 22' RAM 1500
Liked:130 Times in 76 Posts
Anyone here have a c63s (red caliper) that has 18 wheels that clear the red giant af caliper???
Im wondering which wheel companies make an 18 wheel that is compatible with my setup.
thanks in advance.
if youre wondering why? I want 18 wheels for the track
thanks in advance.
Iridium.C63s
close
- Join DateAug 2021
- LocationSoCal
Any advice or info?
Quote:
https://mbworld.org/forums/c63-c63s-...nt-brakes.htmlOriginally Posted by Iridium.C63s
Any advice or info?
Seems like someone has tried to go down your path already!
superswiss
close
- Join DateNov 2018
- LocationSan Francisco Bay Area
- Vehicle(s) I drive2019 C63CS
Liked:5,324 Times in 3,630 Posts
18" won't fit over the larger S brakes. I believe they fit over the smaller non-S brakes, though.
Iridium.C63s
close
- Join DateAug 2021
- LocationSoCal
Quote:
Figured.. thanks man. I know it'll be a downgrade to go with the non s spindle/caliper/rotors but I might just have to go down that route. Originally Posted by superswiss
Iridium.C63s
close
- Join DateAug 2021
- LocationSoCal
im sad... lol another member mentioned only non s will fit and it would be dumb to downgrade to non s parts but then again.. if it can be done why not? im already making cooling ducts for the front brakes so I won't sacrifice heating issues with the front calipers with the non S calipers. Originally Posted by Shlick96
https://mbworld.org/forums/c63-c63s-...nt-brakes.htmlSeems like someone has tried to go down your path already!
Thanks for your reply btw!
Anytime, if your already in the works with the cooling ducts then why not. You can always switch them out at your leisure anyway!Originally Posted by Iridium.C63s
im sad... lol another member mentioned only non s will fit and it would be dumb to downgrade to non s parts but then again.. if it can be done why not? im already making cooling ducts for the front brakes so I won't sacrifice heating issues with the front calipers with the non S calipers.Thanks for your reply btw!
