C63/C63S AMG
2016 c63 amg / Acceleration cutting out for split second
Old Nov 4, 2022 | 04:01 PM
AR AMG's Avatar
C63 AMG
Hi All,
I have a 2016 C63 AMG and on a few occasions when driving, the acceleration has cut out for a split second and then kicks in again. The engine stays on, its just the accelerator?
Any idea of what could cause this? Could this be the gear slipping?
At the same time, the rear caliper is ceasing abit therefore could this have any impact?
If anyone has any ideas, that would be great.
Thanks All!!
Old Nov 4, 2022 | 04:43 PM
user33's Avatar
Hard to tell whether it's related but it is the case that applying brakes with throttle will, after a small number of seconds, cut the throttle. That could be done by sensing the brake-pedal position, which wouldn't apply here, or it could be done by sensing the brake-system pressures, which could apply here if a caliper's piston(s) are not releasing for a few seconds.
Old Nov 4, 2022 | 04:57 PM
AR AMG's Avatar
C63 AMG
Thanks for your feedback buddy. I will have this checked out.
Although, I made an assumption that the caliper my be ceasing. In short, the nearside rear wheel squeeks when driving but the brakepads and disc were changed a few months go.
Thanks!
Old Nov 6, 2022 | 06:32 AM
Belong's Avatar
W205 C63S T
Originally Posted by AR AMG
Hi All,
Thanks All!!
I had 3 leaking injectors , which did the same... engine had knock detection and cut the power...
