Anyone drive an Audi TTRS?
The TT RS was neat to drive a few times. Took it on several canyon runs and for being an FWD with partially engaged rear axle it did not do too bad, but it's a very one dimensional drive as Audis often are. Their AWD implementation doesn't leave a lot of room to play. In case of the TT it's basically FWD with a ton of grip. It's just no Cayman, which is what it competes with technically.
For regular driving, though, it's small and somewhat harsh. Its biggest issue is the suspension. Audi's Magna Ride implementation is not very good. Audi uses a single wheel level sensor and a basic suspension controller to adjust all 4 corners together and the result is poor and a main complaint about the TT RS from current owners. There are aftermarket suspension controllers that improve it by factoring in additional inputs, but the TT RS is missing the sensor array that for example AMG Ride Control uses. AMG Ride Control on our cars has individual accelerometers for each wheel, individual wheel level sensors and additional accelerometers to measure all the forces that are acting on the car and then factors in other inputs such as steering angle, yaw, speed etc. and adjusts the damping rate individually at each corner. The difference is very apparent.
As a primary car I wouldn't get a TT RS. Perhaps as a weekend car, but then I again there's the far superior Cayman. The TT as whole was a style icon, but as a sports car it was never really quite there.
