C63/C63S AMG
255 35 20 fronts?
Old Jan 9, 2023 | 06:32 PM
Belong's Avatar
W205 C63S T
255 35 20 fronts?
Guys im running 255 30 20 now up front... but i would like 255 35 20s better.... will it rub?? or will it be fine?
Old Jan 10, 2023 | 03:41 AM
mars c63s's Avatar
C63s
I think you'd probably be in the best position to judge exactly for yourself than to rely on someone here. (I doubt many would be running that size to advise anyway). With that increase in the aspect ratio it means you'll be 13mm taller (assuming you're sticking with the same tire brand, the width will be the same).
So turn your wheel to both sides and check if you have 13mm over the top of your wheel.
Old Jan 10, 2023 | 06:30 PM
Belong's Avatar
W205 C63S T
You are right... im going for 245 35 20 instead, same sidewall height as the rear 285 30 20, and will look better then the imo too skinny 255 30 ers up front
