C63/C63S AMG
c63s needs new tires 15mm spacers with HR springs
Old Mar 28, 2023 | 04:25 AM
Danisleet's Avatar
C63 AMG
Question c63s needs new tires 15mm spacers with HR springs
Like the title says...
Needing some new rubbers for the c63s (michelin pilot sport 4s), just not sure on size. Currently its tuned stage 1 with HR lowering springs and 15mm spacers all around.
Current tires are not cutting it I cannot use full throttle ever basically.
Current:
F: 245/35/19
R: 265/35/19
Need to understand what you guys think will best fill out the car and give me TRACTION.
Thanks!
Old Mar 28, 2023 | 08:19 AM
pastorius_c63s's Avatar
19' GTC
current set up on stock wheels, H&R and Mode spacer kit
F: 255/35r19
R: 285/35r19
Minor rub on big bumps in the rear, there's a whole thread on here about what tires will and will not fit right on the sedan
Old Mar 29, 2023 | 03:14 PM
Danisleet's Avatar
C63 AMG
F: 255/35r19
R: 285/35r19
Do you plan to re order this same exact tire set-up when it's time?
Old Mar 30, 2023 | 04:01 PM
19' GTC
I went from Yokohama Apex with that set up which run similar height to ps4. I have kumho escta ps91 front and toyo r888r rears currently in the same specs. had to remove rear spacers until i roll my fenders to fit the r888r
