H&R Lowering Spring Long Term Review?
1. How long have you been lowered and thoughts?
2. How's the tire wear, is it really as bad as people claim to be?
3. Drop a photo and show your setup if you can!
I drive daily and very spirited every where I go. Wouldn't mind a 20% increase in tire wear, but definitely not switching out tires every 3k miles.
Edit: Also, not looking to get a camber kit nor bushings.
Definitely more camber, maybe a little stiffer, however I always drove in sport plus before so I can’t say for sure it’s really that different.
the look is where it’s at. I would do it again for sure.
I have other pictures posted I’m another thread after it got done. I’ll have to find those. There are taken right after I put new tires on.
295/30 rear and 255/35 front. 15 mm spacer up front and 12 mm in the back. Although I think I’m going to go down to a 10 mm in the rear.
https://mbworld.org/forums/c63-c63s-...ml#post8552848
