Is this the correct brake kit for my C63s
https://www.fcpeuro.com/products/mer...mbo-0004206600
I was told by the shop to double check because the actual OE part for the brakes is 2314211812 and that isn't listed in the description of OE numbers. The description also says retro fit so I'm guessing it will work, but just wanted to make sure. Thanks!
Have you noticed much difference vs the stock rotors, either positive or negative? I've had performance pads on cars before and had terrible squealing and definitely don't want that on my C63S
TIA
PS: Could you tell us what rears you're using with these Black Series fronts? Just the Zimmerman C63 S rears?
https://www.bremboparts.com/europe/e...isc/09-B848-33
Whereas these upgrade discs are A2304211212
https://www.bremboparts.com/europe/e...isc/09-9313-33
Comparing the spec sheets, appears that it saves 900g per side too!
As you can see by photos the rear rotors hats have taken on ugly rust. Probable from winter salt. The MB dealership will not cover under warranty as they say it does not effect braking. So the plan is to order new rear rotors and brakes and before having them installed have the rotor hat area Powder Coated with a color as close as possible to same color are the rotor hats. Any other suggestion will be helpful. The Zimmermann rotors are zinc coated but believe these will help prevent some rust but not all.
TIA
Yes, I went with FCP's rear kit with the Zimmermann rotors. They are pretty much identical to the OE rotors in the looks department and Zimmermann are great rotors. The rear caliper in our cars is floating, so going with full floating rotors doesn't add anything, other than perhaps looks, but the stock front and rear rotors already look different on the S as it is, so it doesn't bother me.
No theyre not.. just a random picture..
So I have to ask, what is it that the stock pads are not delivering for you? If it's about brake dust then you have to go with ceramic pads, but those simply don't have the initial bite and do poorly when cold.
https://www.brembo.com/en/company/news/new-ventilation
My Zimmerman fronts i bought in a combo with pads ( which are kinda **** ) the HPS 5.0 are alot cheaper then the oem pads... thats why i was asking...
Cheers
