how tall can the front lift without oil starvation
front wheels will be on these cribs https://www.raceramps.com/cribs/wheel/p/rr-wc-12/
rear wheels will sit on this ramp https://www.raceramps.com/ramps/trax-jax/p/rr-tj/
Personally I would level the vehicle while performing the engine oil and filter change, although it does not mention it in WIS, all maintenance is performed on a lift with the vehicle level. I always jack up the rear and place it on jack stands to level the vehicle while I am performing maintenance.
Just in case you do not have it, I have attached the Engine Oil and Filter change procedures to this post.
Good luck!
Good luck!
Good luck!
Today it’s oil change day and brake flush. Got a HPDE event in Sebring this month. All other fluids are done. Well besides coolant as I read it’s like 10 year fluid vs every 3 years like other cars.
