A year ago, during a service check at 5,000 kilometers, errors due to improper positioning of the exhaust valve camshaft actuator were identified, despite the absence of any negative symptoms or loss of power. No warning lights were illuminated. The service workshop suggested that these errors might have been triggered by the car being parked for an extended period and recommended a recheck. This year, the same errors persist. The service team is now proposing the replacement of two solenoids (adjuster magnets) releated to the exhaust valves, although they are uncertain about the result. The cost of the solenoids is not high, but the replacement cost is significant due to challenging access, involving two full days of mechanic work.
Could you please share your advice and experiences on this matter? Generally, they don't know much about this matter. Initially, they thought they would replace it within a few hours.
update: Xentry error number is P002477
Iridium.C63s
close
- Join DateAug 2021
- LocationSoCal
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive16' C63s, 22' RAM 1500
Liked:130 Times in 76 Posts
I've replaced the cam adjuster magnets, simple job, just time consuming and removal of the intercoolers was a bit tideous. All in all if you could afford the replacement go for it but it is a $5.6k job without parts. I spent around $500 (includes beer).
MB says its an 10 hour job I finished it around 11hrs. (friend lent me his 2 post car lift and made it alot easier.)
I now have to replace the actual camshaft sprockets and have to do this without the car post lift yet I got myself Quickjax system so it should roughly be the same time.
Have fun wrenching if you choose to
Iridium.C63s
close
- Join DateAug 2021
- LocationSoCal
Also, I can agree that there is no loss of power with these codes. but I do have long 3-5 second long cranking sometimes.Originally Posted by keraj
A year ago, during a service check at 5,000 kilometers, errors due to improper positioning of the exhaust valve camshaft actuator were identified, despite the absence of any negative symptoms or loss of power. No warning lights were illuminated. The service workshop suggested that these errors might have been triggered by the car being parked for an extended period and recommended a recheck. This year, the same errors persist. The service team is now proposing the replacement of two solenoids (adjuster magnets) releated to the exhaust valves, although they are uncertain about the result. The cost of the solenoids is not high, but the replacement cost is significant due to challenging access, involving two full days of mechanic work.Could you please share your advice and experiences on this matter? Generally, they don't know much about this matter. Initially, they thought they would replace it within a few hours.
Did you ever figure this out? Originally Posted by keraj
Quote:
Hi, it’s great that you’re asking because I forgot to update our forum community on the results. I didn’t replace the solenoids, and I avoided an expensive repair. I solved the issue, and everything has been fine for the past year and a half! It turned out that after a routine oil change, the errors stopped appearing.Originally Posted by Aliw140
I started investigating...
From the XENTRY printouts, I noticed that these errors occurred exclusively on a cold engine (I should note that I only drive in summer). These disappeared just after the last oil change—from the old Genuine MB 229.5 5W40 to the new Mobil 1 FS 0W40—the errors stopped appearing and never came back.
I’m disappointed with the authorized Mercedes dealer, who mentioned they suspected the old oil might be the issue but still filled my car with the standard 5W40 without even asking if I’d pay extra for a better one. While it’s true that 5W40 is compatible according to the manual, it clearly doesn’t work as expected in practice.
To summarize the whole story, oil with a "0" as the lower number simply performs much better on a cold engine—even in summer—and allows the variable valve timing solenoids to move properly. It’s worth using, even if the car isn’t driven in winter. I’m not sure if the errors would occur with the genuine High Performance Engine Oil MB 229.5 0W40, but I’m not going to test it. This Mobil 1 FS, which is widely recommended online, works great and is also very affordable.
