C63/C63S AMG
P1CCF code no CEL - C63S 2018
Old Oct 1, 2023 | 05:19 PM
OkC63s's Avatar
2018 C63s
Hello my 2018 c63s is having long crank times randomly I decided to throw my cheap code reader in it and it read P1CCF. Is anyone else having this problem or had this problem? There is no rough idle and it drives perfect also no Check engine light. Only had it 2 months. Any help is appreciated thanks All in advance🙏!
Old Oct 3, 2023 | 09:40 PM
Jimmy_c63s's Avatar
That's a fuel pressure code for start up. Usually if the high pressure fuel pump isn't able work enough fuel on starting the car. Hence why you are having long startup attempts.
Clear it, put some new gas in and scan again after the tank gets to halfway mark.
Let us know how it goes man. Is your car tuned by the way?
Old Oct 3, 2023 | 10:34 PM
OkC63s's Avatar
2018 C63s
Thanks for the reply! Car is not tuned and i will try this TMR thanks again!
Old Oct 7, 2023 | 01:22 AM
Jimmy_c63s's Avatar
How did it go matey?
