C63/C63S AMG
Oil in cylinder 7... where from?
Old Jan 24, 2024 | 04:42 PM
raphman's Avatar
'16 C63s
Hi folks,
Did my spark plugs today (currently has 77k-ish miles, plugs last done at 60k) and noticed that the spark plug from cylinder 7 (second from firewall, driver's side) had a very noticeable amount of oil on the tip and threads; threads were practically covered in oil. With my borescope I was able to look in the cylinder and there was a little pool of oil at the bottom.
Doubt it's the piston rings, as there's no smoke from the exhaust. Also, all other cylinders / plugs looked fine. I don't have a compression tester so was not able to test, and had to button everything back up to get back on the road.
Anyone ever come across this on the M177? Any ideas? I'm guessing valve cover gasket? If so, who has done them and how much of a pain is it?
Car is a PFL.
Old Jan 24, 2024 | 04:45 PM
hotdognobun's Avatar
C63S Coupe/CLA45
Originally Posted by raphman
Hi folks,
Car is a PFL.
Any misfire?
Old Jan 24, 2024 | 04:47 PM
raphman's Avatar
'16 C63s
Originally Posted by hotdognobun
Any misfire?
Nope, runs perfectly fine - no codes or misfires... pulls hard and boosts to full capacity on screen gauge
Old Jan 24, 2024 | 07:05 PM
chassis's Avatar
2017 GLE350 4MATIC
Oil in cylinder and no smoke from the tailpipe? That doesn't add up.
Read codes
Compression check
Borescope again to look for scoring
Old Jan 24, 2024 | 07:11 PM
raphman's Avatar
'16 C63s
Read codes
Compression check
You're telling me... odd as hell. During borescope I noticed a darker streak or line in the cylinder, which lined up to where the oil was pooling at the top of the piston.
I'll have to order a compression tester, and no codes.
Old Jan 25, 2024 | 11:18 AM
Dexter Talbert's Avatar
2017 AMG C63s
I’m going to guess the oil was overfilled a little.
Old Jan 25, 2024 | 12:14 PM
raphman's Avatar
'16 C63s
Found it... found the stupid culprit: valve cover gasket. Turns out it was leaking right where it aligns with the cylinder 7.
I pulled the ignition coil today and was able to see it all - the tiny spot where the oil is coming out, leaking down into the spark plug shaft. The spark plug boot was moist with oil and there was some pooling of oil where the plug seats.
The oil i observed yesterday must've dripped down into the cylinder and top of the piston when I removed the plug.
On that note, anyone done valve cover gasket on our cars? How much of a PITA was it and, if taken to a shop, what was the damage $$ ?
Old Jan 25, 2024 | 12:17 PM
2017 AMG C63s
I had this happen to my PFL C63 and it eventually dried 😖. I almost made sure to drain the oil completely and be careful when filling it. But it eventually dried and never had any more issues with the valve gasket leaking. I think it could be an extensive job (may have to pull the engine?)
Old Jan 25, 2024 | 12:20 PM
raphman's Avatar
'16 C63s
My concern here is that more pooled / accumulated between yesterday's plug change and today when I went to inspect further, so it's certainly an ongoing leak. I don't want it to completely fill the spark plug shaft... I'm sure that would be a whole lotta suck.
Old Jan 25, 2024 | 12:29 PM
chassis's Avatar
2017 GLE350 4MATIC
MB engine covers and plates are generally adhered using adhesive. Careful cleaning away of the old sealant and avoiding damage of the machined mating surface is important. And use of the proper MB sealant with proper application quantity and location are important. Plus removal and disassembly of parts, probably breaking one or two heat-aged items in the process that need to be replaced.
If you are comfortable with all of that, it’s not hard. If it were me I would have an Indy do it.
Old Jan 25, 2024 | 12:30 PM
raphman's Avatar
'16 C63s
Yeah, that's the route I'm thinking as well, just curious of the financial damage.
