C63/C63S AMG
Injector cleaning
Old May 7, 2024 | 01:11 AM
kwonnycash's Avatar
2016 c63 wagon
Injector cleaning
Anyone has had there injectors cleaned?
and if so at how many miles,km?
not that my car has any issuses just wondering when or how you guys did it
Old May 7, 2024 | 01:58 AM
streborx's Avatar
Top Answer: 1
G550
Every ICE vehicle now sold uses fuel injection and gasoline is formulated to keep injectors clean. Back when this wasn't the case, Techron was regarded the best fuel injector cleaner. If you think a fuel additive such as this is necessary, read up a bit and decide if you think it's worth adding. Most car manufacturers recommend no additives of any kind. I haven't bought a bottle of Techron in a very long time. If you think your injectors require physical removal and maintenance, I'd consult the dealer or a good mechanic.
Old May 7, 2024 | 03:04 AM
jj18's Avatar
2019 C63S Coupe
My yearly MB Service they include a Fuel Injector cleaner for preventative maintenance. The SA advises to put it in the gss tank when it's at 1/4 full and then fill up as this will mix /blend better than just adding it to a full tank.
