C63/C63S AMG
Urgent Help Needed (Engine Mounts)
Old Jul 8, 2024 | 05:40 PM
SamSaab's Avatar
C300
Guys, so I’ve been researching a lot because my 2018 C63s has been juddering and shaking idling on D and on P, N and what not. Took it to couple of certified services and they all said that the engine mounts are worn out af.
So I could not find the needed active engine mounts and they are super expensive (~$3k for both) but I was wondering if a can fit the non-active (non-S) mount on my car ($800 for both). I don’t care about the dynamic control because honestly speaking it doesn’t do much.
the question is will they fit and will I have to only clear the codes with a regular OBDII or does it require something else.
please if any of you tried something like that appreciate if you can give me a brief of the possibility.
if you took a close look at both, the active one has some sort of concealed fluid and a plug on its side, the non-active is a rubber top. All have the same screw positions and similar top fitments.
Old Nov 28, 2024 | 10:31 AM
MBEnt63's Avatar
c63s
what did you end up doing?
